car swerves when i brake hard..
Old Mar 2, 2005 | 11:07 PM
crxtreme27's Avatar
Default car swerves when i brake hard..
ok guys, lately i noticed that when i step on the brakes, the car seems to swerve left and right when im on the freeway or any speed above 35mph... does anyone know what might be wrong???
thanks
Old Mar 2, 2005 | 11:18 PM
90civichbsi's Avatar
Default Re: car swerves when i brake hard.. (crxtreme27)
your rear toe is probably off, that or one of your rear wheel cylinders (or calipers if you have rear disks) isnt working properly
Old Mar 3, 2005 | 01:10 AM
jisu009's Avatar
Default Re: car swerves when i brake hard.. (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">your rear toe is probably off, that or one of your rear wheel cylinders (or calipers if you have rear disks) isnt working properly</TD></TR></TABLE>
and check your radius rod bolts, make sure they are tight...
Old Mar 3, 2005 | 11:44 AM
crxtreme27's Avatar
ok guyz, how do i check that?? sorry, i have never really worked with breaks or any type of suspension..
Old Mar 3, 2005 | 12:15 PM
manson's Avatar
first things first.... check your tire pressure. usually if one is higher or lower than the other you can get some swerving.
your alignment may also be off and that would also cause swerving.
if your not familiar with your brake system i would suggest a mechanic to take a look at it. brakes are not something you want to mess up.
Old Mar 3, 2005 | 12:23 PM
RCautoworks's Avatar
Why would rear toe cause the car to swerve only when the brakes are applied ?
Check the basic stuff like tire pressure, but if its really swerving to one side, say the right side, then either a caliper or wheel cylinder on the right side could be sticking, but usually if it sticks the car is gonna want to pull a little when you left off the brake.
Another scenario, say your car pulls to the right when braking, well the left side of the braking system might not be working right, but rather then sticking out, the caliper or wheel cylinder could be stuck inside, causing only the right side to have clamping force, there fore the car will put to that side.
Old Mar 3, 2005 | 01:22 PM
menappi's Avatar
get an alignment, does your steering wheel turn when u hit bumps also or does the car vear to one side of the road when u let go?
Old Mar 4, 2005 | 09:08 PM
crxtreme27's Avatar
Default Re: (menappi)
I think the alignment if fine because i just got one less than a year ago, and well the steering wheel doesnt move like dat on bums or similar things...
But i will check the brakes this weekend, thanx for ur help guyz
dgdarien
Suspension & Brakes
Apr 7, 2017 05:37 PM
Koko4
15
Sep 16, 2013 06:17 AM
TN90accord
Jan 21, 2008 10:31 AM
eg686
21
Apr 4, 2005 05:07 PM
Understeer
Sep 16, 2002 08:44 PM
