cat converter
Old Jan 21, 2002 | 01:28 PM
paulyman's Avatar
Default cat converter
hi guys
reemed my stock cat out
didnt feel like spending the money on a high flow cat.
230 bucks or more.
well my enigne light is on now
i probably will get a high flow cat someday
but for now does anyone know how to over ride the o2 sensor
or make it read right
so the light goes of
and my car doesnt run rich anymore
thanxs
Old Jan 21, 2002 | 01:34 PM
EGtoR's Avatar
Default Re: cat converter (paulyman)
The O2 sensor at the cat didn't do anything except to tell the ECU the cat is functional or not. Your car would run as normal as when the CEL is not on. So if you want, just put a black tape over the CEL, so you won't see it.
Old Jan 21, 2002 | 01:42 PM
paulyman's Avatar
Default Re: cat converter (EGtoR)
kinda wana overide it though
i would like to keep my light off
in case the engine light goes on someday for something more important.
would my light still go off if i put on a high flow cat?
Old Jan 21, 2002 | 02:05 PM
Dropspeed's Avatar
No, if you put a high flow cat on your CEL would not come on.
Old Jan 21, 2002 | 02:13 PM
whttyper1998's Avatar
New User
Default Re: cat converter (Dropspeed)
Take tin foil and wrap the O2 sensor with metal wire. Reset the ECU and your CEL will go away. This should last for several months until the tin foil burns away.
Old Jan 21, 2002 | 02:44 PM
Keane Rated R's Avatar
Default Re: cat converter (whttyper1998)
why is the light on? are there two censors on the usdm model? I checked mine, was thinking of removing and there was only one censor, and that was infront of the cat converter so it wouldnt make a difference to the censor if it was removed
Old Jan 21, 2002 | 02:48 PM
paulyman's Avatar
Default Re: cat converter (Integra Rated R)
i have a 2000
on mine they put a sensor before the cat
and in the cat
it sucks
the stock cat really is restrictive
now that i have honed it out my car is noticably faster an alittle louder
Old Jan 21, 2002 | 02:49 PM
there is no sensor in the cat in my car, weird
mystikz2002
Sep 23, 2005 06:20 PM
JoshuaVTEC
Sep 7, 2005 12:43 PM
paulyman
Jan 21, 2002 02:09 PM
01itr518
Nov 6, 2001 10:10 AM
