Difference between chromoly and mild steel??
Whatis the difference between the two metals??
I am looking at making traction bars and I wanted to know the characteristic differences between the two metals!
Thanks!
Thanks!
DOM Mild steel is a light gray color, chromoly is a dark brown color
chromoly-
http://www.mckeone.net/photos/cage/P9220001.JPG
mild-
http://www.jmfabrications.com/...4.jpg
If that helps any
chromoly-
mild-
If that helps any
<U>1020 Mild Steel, cold rolled</U>
Component Wt. %
C 0.17 - 0.23
Fe 99.08 - 99.53
Mn 0.3 - 0.6
P Max 0.04
S Max 0.05
Density - 0.284 lb/in^3
Brinnell Hardness - 121
Yield Tensile Strength - 50.8 ksi
Ultimate Tensile Strength - 60.9 ksi
Shear Modulus - 11600 ksi
Modulus of Elasticity - 29.7 ksi
<U>1212 Mild, cold drawn</U>
Component Wt. %
C Max 0.13
Fe 98.52 - 99.07
Mn 0.7 - 1
P 0.07 - 0.12
S 0.16 - 0.23
Brinnell Hardness - 167
Yield Tensile Strength - 60.2 ksi
Ultimate Tensile Strength - 78.3 ksi
Modulus of Elasticity - 29.0 ksi
<U>4130 Chromium-Molybdenum, Normalized at 1600 F</U>
Component Wt. %
C 0.28 - 0.33
Cr 0.8 - 1.1
Fe 97.3 - 98.22
Mn 0.4 - 0.6
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.35
Brinnell Hardness - 197
Yield Tensile Strength - 63.1 ksi
Ultimate Tensile Strength - 97.2 ksi
<U>4130 Steel, water quenched 1570°F, 1000°F temper</U>
Component Wt. %
C 0.28 - 0.33
Cr 0.8 - 1.1
Fe 97.3 - 98.22
Mn 0.4 - 0.6
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.35
Brinnell Hardness - 302
Yield Tensile Strength - 142.0 ksi
Ultimate Tensile Strength - 151.0 ksi
<U>4140 Steel, normalized at 1600°F, air cooled</U>
Component Wt. %
C 0.38 - 0.43
Cr 0.8 - 1.1
Fe 96.785 - 97.84
Mn 0.7 - 1
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.3
Yield Tensile Strength - 97.9 ksi
Ultimate Tensile Strength - 148.0 ksi
That's all you're getting, that took forever....
Component Wt. %
C 0.17 - 0.23
Fe 99.08 - 99.53
Mn 0.3 - 0.6
P Max 0.04
S Max 0.05
Component Wt. %
C Max 0.13
Fe 98.52 - 99.07
Mn 0.7 - 1
P 0.07 - 0.12
S 0.16 - 0.23
Component Wt. %
C 0.28 - 0.33
Cr 0.8 - 1.1
Fe 97.3 - 98.22
Mn 0.4 - 0.6
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.35
Component Wt. %
C 0.28 - 0.33
Cr 0.8 - 1.1
Fe 97.3 - 98.22
Mn 0.4 - 0.6
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.35
Component Wt. %
C 0.38 - 0.43
Cr 0.8 - 1.1
Fe 96.785 - 97.84
Mn 0.7 - 1
Mo 0.15 - 0.25
P Max 0.035
S Max 0.04
Si 0.15 - 0.3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish »</TD></TR><TR><TD CLASS="quote"><U>[B]...
That's all you're getting, that took forever....</TD></TR></TABLE>
You should've just sent him to http://www.matweb.com.
silverEH2
May 9, 2003 05:45 AM
4130, 4140, chromoly, density, difference, elasticity, elasticiy, ksi, metal, mild, modulus, moly, normalized, ofchromoly, shear, steel
