what is this Relay?......Civic 96
Old Mar 2, 2005 | 06:55 PM
gamakichi77's Avatar
Default what is this Relay?......Civic 96
anybody know what relay is this?..located under dashboard, civic 96......its not main relay rite?..thanks.
what happen if i disconnect this relay?..coz 3 wire connected to it already cut off.....
Old Mar 2, 2005 | 07:05 PM
Default Re: what is this Relay?......Civic 96 (acidburns_di)
and here the picture of wire coned been cut off...........help me please before i disconnected this relay...........
Old Mar 2, 2005 | 07:18 PM
drdisco69's Avatar
No, that's not the main relay. It would appear to be (tada!) the interlock control. I think it's made in japan... JDM!
Old Mar 2, 2005 | 07:31 PM
adictionbass's Avatar
Default Re: what is this Relay?......Civic 96 (drdisco69)
it says interlock on it mad big y0!
Old Mar 2, 2005 | 07:49 PM
for what purpose is this interlock control?........is it will effect anything if i disconnect it?
Old Mar 9, 2005 | 11:57 PM
anybody could explain it to me?
Old Mar 10, 2005 | 05:46 AM
JimBlake's Avatar
Is that related to the starter interlock system? That stuff doesn't let you start the engine unless the clutch pedal is pressed down. Or with an auto trans, it has to be in P or N.
Old Mar 10, 2005 | 12:22 PM
Ls_V_TurboSi's Avatar
Default Re: what is this Relay?......Civic 96 (JimBlake)
Im guessing it could have something to do with your power door locks..
Old Mar 10, 2005 | 03:38 PM
drdisco69's Avatar
Default Re: what is this Relay?......Civic 96 (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">Im guessing it could have something to do with your power door locks..</TD></TR></TABLE>
Nope, it is in the contol unit for the shift interlock circuit:
It makes sure you can't remove the key when the car is out of park. I can't tell what wires are cut so I can't tell what effect they will have. See if you can get the colors, or a better picture.
Old Mar 10, 2005 | 04:59 PM
actually previously my stock engine is D15B auto tranny. rite now already converted to B16A manual tranny........
and wire cut off is yellow, green and black........what will be effected if i disconnect this interlock relay?
Old Mar 10, 2005 | 05:27 PM
drdisco69's Avatar
If you can remove the key from the ignition normally, then the interlock has no effect on anything else.
Just for future reference, some wires in Hondas have 2 colors on them, a solid color that covers the wire, and a thin stripe running down one side. Both colors are needed to determine the right wire. In this case, the yellow wire has a black stripe, the green wire has a white stripe, and the black wire is just black. You can see all this from the wiring diagram and the labels for each wire. The main color is listed first, then the color of the stripe is listed after the slash (/).
Sorry for rambling, just trying to avoid confusion in the future.
Old Mar 10, 2005 | 09:33 PM
thanks brother.........really appreciate it......
Old Mar 10, 2005 | 09:34 PM
Default Re: (acidburns_di)
so, now if i disconnectt the interlock, nothing will be efected rite........
Kevedge
Nov 21, 2004 07:42 AM
Nameless RB26
Jul 29, 2003 03:46 PM
