H and R lowering springs 94 accord
Old Mar 2, 2005 | 05:36 PM
Kuyababoy03's Avatar
Default H and R lowering springs 94 accord
i plan on getting h and r lowering springs this weekend and i was wondering if anyone has done this already .. if so .... how hard is it to install the back springs and wat are the alignment specs. and post pix if u have plz...........
Old Mar 2, 2005 | 06:11 PM
jagged4698's Avatar
Default Re: H and R lowering springs 94 accord (Kuyababoy03)
Wasn't too hard the biggest problem i ran into was not being able to break the back botom bolts lose.. so i ended up destorying and replacing the bushing. I would suggest spray it with lube a couple days prior to doing this.. and do it repeatedly... other then that its pretty simple.. lube and a haynes, chiltons, etc will be your best friend
Old Mar 2, 2005 | 07:05 PM
LordAccord's Avatar
Default Re: H and R lowering springs 94 accord (jagged4698)
Alignment is different on every single car. Just get it checked once you install
You really should install some aftermarket shocks with those springs, though.
Old Mar 2, 2005 | 09:49 PM
tonezilla's Avatar
Default Re: H and R lowering springs 94 accord (LordAccord)
i have the h&r sport springs on stock shocks on my 94 accord . when i went to get my car aligned, the spec came out to be between -1.5 & -2.0 all around . it took about 2 hours to install with a friend .
http://g.myspace.com/00045/48/21/45071284_l.jpg
Old Mar 3, 2005 | 12:27 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: H and R lowering springs 94 accord (redxalien)
Yeah just get the Haynes and a spring compressor. Both can be had at Autozone.
I thought it was a huge pain in the ***, not terribly difficult by technical means, just more time consuming than I wanted.
Old Mar 3, 2005 | 03:44 AM
Mike813's Avatar
Default Re: H and R lowering springs 94 accord (ForcedAccord)
https://honda-tech.com/zerothread?id=1151772 thats the outcome after install...
but for rears alot of people have broken bolts, so have a pair ready just in case... and its always good to change it out since youre down there anyway... i would change the boots also.
Acco12dv6
Jul 20, 2007 10:37 PM
abeaujuin
Sep 12, 2003 04:30 AM
hondachic808
Jun 11, 2003 07:50 PM
far
Jan 24, 2002 08:28 AM
