all motor problem
Old Mar 2, 2005 | 04:07 PM
greenb20's Avatar
Default all motor problem
i have a built b20 with high comprssion...i have ctr cams, dual valve springs, not much..the other day i noticed smoke coming out of the valve cover hole..i know its burning oil...anyways its the hole where u can put a breather or tube...i dont really know whats wrong..if any one has info on this please let me know..thanks
Old Mar 3, 2005 | 10:07 PM
chameleon's Avatar
Default Re: all motor problem (greenb20)
do a compression test, your rings might be shot, when i had fried of of my rings on my turbo motor is smoked from everywhere, a ton from that spot your talking about so do a comp test and then a leak down.
Old Mar 4, 2005 | 12:51 AM
Terrible One's Avatar
Default Re: all motor problem (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test, your rings might be shot, when i had fried of of my rings on my turbo motor is smoked from everywhere, a ton from that spot your talking about so do a comp test and then a leak down.</TD></TR></TABLE>
same here
Old Mar 4, 2005 | 08:35 AM
98lsskunk's Avatar
its normal to have a little bit of smoke coming out of that hole but not its alot and you are noticing oil consumption.
1sikhatch
Apr 26, 2007 02:22 PM
vxturbociv
Jul 23, 2006 06:27 PM
silverboost
Nov 8, 2005 01:01 PM
fastfu
Jun 30, 2004 11:59 AM
ALLMOTOR18
Dec 27, 2003 07:54 AM
