Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
2000 Civic Si 15x7 offset question
Old Mar 2, 2005 | 12:44 PM
Civic44's Avatar
Default 2000 Civic Si 15x7 offset question
I have a 2000 Civic Si race car. I am currently running a 15x7 wheel with 38 mm offset and 205-50-15 Hankook Ventus Z211. This works fine with rolled fenders. There is no rubbing. I am ordering a scond set of wheels, some Team Dynamic Pro Race 1, and the choices are 25, 35 or 40 offset. I'm wondering if I can get away with 35 or even 25 offset if I continue to run 205 width tires. Anybody have experience with this? Thanks.
Old Mar 2, 2005 | 01:21 PM
philstireservice's Avatar
Default Re: 2000 Civic Si 15x7 offset question (Civic44)
I would pick the 35mm offset.......
Old Mar 2, 2005 | 02:27 PM
Dan GSR's Avatar
40 should be fine
Old Mar 2, 2005 | 02:50 PM
ryan12321's Avatar
Default Re: 2000 Civic Si 15x7 offset question (Dan GSR)
I was able to get 35 to fit easily with rolling my fenders.
Heres mine with my ATS wheels
Modified by ryan12321 at 9:01 AM 3/3/2005
Old Mar 3, 2005 | 04:43 AM
the reason I suggested 35mm is in case you wanted to run wider tires in the future. Otherwise, 40mm will work......
Old Mar 3, 2005 | 05:59 AM
bbqman's Avatar
I am sure that 40 offset clears, I am wondering if there is an advantage in running 35 or even a 25 offset to gain track?
Old Mar 3, 2005 | 10:23 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: 2000 Civic Si 15x7 offset question (bbqman)
running a 10 mm spacer would have the same effect. when i get a chance i will datalog a session with, and then with out spacers... it's not that significat since the CG is pretty high on production cars.
Old Mar 3, 2005 | 10:27 AM
MattD@Stoptech's Avatar
Default Re: 2000 Civic Si 15x7 offset question (ghettoracer)
Except j00'll most likely need longer studs....that's not the case when the wheels have correct offset from the getgo.
vrquick
Nov 8, 2009 01:27 PM
gg emerican
Honda Civic (2006 - 2015)
Mar 28, 2009 08:08 AM
CivicSiRacer
15
May 14, 2004 05:14 PM
