IDLE
Old Mar 2, 2005 | 12:06 PM
barry11j's Avatar
Default IDLE
my car is also idiling funny. sometimes it idles at 800 then it jumps to about 2500...even when i got the clutch in it idles high...help?
Old Mar 2, 2005 | 12:09 PM
screwmesa's Avatar
Default Re: IDLE (barry11j)
check sensors....map and tps. ecu throwing any codes?
Old Mar 2, 2005 | 12:10 PM
barry11j's Avatar
Default Re: IDLE (screwmesa)
just my vtec syn no other codes...do you think i jumped timing?
Old Mar 3, 2005 | 05:52 AM
barry11j's Avatar
any 1 else have any ideas that i can look 4 today
Old Mar 9, 2005 | 06:58 AM
barry11j's Avatar
does any 1 have any ideas please help
Old Mar 9, 2005 | 07:11 AM
Filthy Focker!'s Avatar
1. vacuum leak. whether on the IM or a line, something's leaking
2. IACV (Idle Air Control Valve) problem. possibly a bad valve, or a bad double-O ring on it, causing a vacuum leak (happens a lot)
3. O2 sensor problem.
4. TPS (Throttle Position Sensor). Check with a voltmeter from 1-5 volts
5. MAP sensor. probably not the culprit, but it could be going out, or be leaking vacuum at it's base.
6. Air pocket in the cooling system. Not very likely, but has happened before.
fs
webbs2jzgte
Jul 9, 2009 03:23 PM
Bboy_Trevstuh817
Jan 7, 2007 10:31 PM
talley2191
Jan 31, 2006 07:13 PM
CA6VTEC
Sep 14, 2004 05:57 PM
Kamin
Jan 12, 2002 08:43 AM
