power windows malfunctioning
Old Mar 2, 2005 | 11:05 AM
holeeray's Avatar
Default power windows malfunctioning
i have a '97 4 door accord and on the driver's side, the power window is malfunctioning. i can bring it down without a problem, but when i try to roll the window back up, it's like the power cuts and i have to repeatedly press the up button on the window control in order to close it. is it time for a new motor?
Old Mar 2, 2005 | 12:13 PM
alotawatts's Avatar
Default Re: power windows malfunctioning (holeeray)
Unless the motor has puked try a silicone spray lube in the window channels/tracks. Helped mine. The motor is working twice has hard to lift.
Old Mar 2, 2005 | 09:07 PM
Toldge's Avatar
Default Re: power windows malfunctioning (alotawatts)
i have the same problem with my 96, i've tried everything in hopes of getting the window to go up smoothly w/o me having to lube up the tracks every week
no dice tho, just get used to spraying the tracks down with silicon spray everytime you wash the car
Old Mar 4, 2005 | 01:57 PM
businessmanph's Avatar
Default Re: power windows malfunctioning (Toldge)
so when the window is up you spray between the window and the rubber moldings inside the door, do you spray from the inside and outside?
Old Mar 6, 2005 | 01:36 PM
Default Re: power windows malfunctioning (businessmanph)
I sprayed the silicone between the window tracks. It didn't do **** but, make my windows greasy. I think I should take the door panel off.
hondapwr
Jul 28, 2007 06:55 PM
4Dinsaneb16
Mar 20, 2007 01:30 PM
.jacob
11
Mar 3, 2003 05:25 AM
