Coolant Comming out of Manifold Bolt Hole
Old Mar 2, 2005 | 10:11 AM
Ls InTeGrA RaCeR's Avatar
Default Coolant Comming out of Manifold Bolt Hole
I had to have this bolt extracted because the head broke off (old bolt, not over tightened) about 5 months ago (put a new bolt in). Now I have Coolant leaking out of that exact same bolt. Is there any way to fix this problem or am I looking at another fun project?
Old Mar 2, 2005 | 11:00 AM
Default Re: Coolant Comming out of Manifold Bolt Hole (Ls InTeGrA RaCeR)
no one has any suggestions?
Old Mar 2, 2005 | 11:23 AM
Dogginator's Avatar
Daisy... Daisy...
Am I correct to assume that you are referring to the intake manifold? Which motor? Did you remove the aforementioned manifold when this bolt broke? Was the gasket replaced? Were the bolts torqued properly and in sequence?
Old Mar 2, 2005 | 11:38 AM
3.504's Avatar
Default Re: Coolant Comming out of Manifold Bolt Hole (Dogginator)
as soon as i read the title i thought mani gasket. you also might want to try some teflon paste on the stud end to seal the whole so coolant doesn't puddle inside of it. remember to work inside out in a circular pattern when torquing back on (and to proper torque spec)
its the exhaust manifold, all bolts were tightened in proper order and new gasket was applied.
Old Mar 2, 2005 | 11:56 AM
Dogginator's Avatar
Daisy... Daisy...
I don't think that coolant flows around the exhaust manifold. (I could be wrong.) Does this bolt lead to a coolant passage? Is it possible that the head cracked near that broken bolt?
Old Mar 2, 2005 | 12:15 PM
3.504's Avatar
exhaust mani! holy crap! you may have just tapped into a jacket by accident when fixing the threads, or it could be cracked. the cheapest and easiest way to get a semi fix would be to teflon tape the stud and re-install it. the other way would be to fill the bottom of the whole with epoxy (or you could go cheap and easy and use liquid metal or jbweld). then re-install stud.
Old Mar 2, 2005 | 12:33 PM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">its the exhaust manifold, all bolts were tightened in proper order and new gasket was applied.</TD></TR></TABLE>
That's not good at all. How did you go about extracting the old bolt? If you drilled it you may have went too far and made a hole into the coolant passage. Hopefully this is what happened and you didn't crack the head. I would pull that new stud out of there and take a look in there (shouldn't be too hard if you just replaced it). You could even start the car to see if it shoots out of the hole just to make sure it isn't leaking from the headgasket.
If you did just drill too far then I think you could get away with just putting some teflon tape on the stud when you reinstall it. I'm not sure how it'll react to the heat of the exhaust but it's worth a shot.
Swansen
Jun 15, 2015 03:26 PM
bopbop93030
Aug 12, 2009 08:22 PM
tegh22a
Aug 26, 2005 09:22 AM
Stu
Jan 15, 2004 01:19 PM
