Welding Quarter Panels TO EG
i cutted out my rusted areas and my instructor was telling me to overlap the new sheet over the old by about a inch in a half. is this correct? or the right way? i was thinking it'd be better to line up the old metal and new together then weld. welps give me some help here i only got two hours from now. thanks
do you know anything about civic 96 ex i wondering if u knoe what type of ecu is it for the stock one cuz i trying to buy hardness for it, it is a obd1 ob2 or obdo and also do you how to wire up my civic i also going to put a b20- with a gsr head up in thea hollar back aight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20-TyR »</TD></TR><TR><TD CLASS="quote">do you know anything about civic 96 ex i wondering if u knoe what type of ecu is it for the stock one cuz i trying to buy hardness for it, it is a obd1 ob2 or obdo and also do you how to wire up my civic i also going to put a b20- with a gsr head up in thea hollar back aight?
You need an OBD2 GSR ECU and harness.
</TD></TR></TABLE>You need an OBD2 GSR ECU and harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ch4nq »</TD></TR><TR><TD CLASS="quote">i cutted out my rusted areas and my instructor was telling me to overlap the new sheet over the old by about a inch in a half. is this correct? or the right way? i was thinking it'd be better to line up the old metal and new together then weld. welps give me some help here i only got two hours from now. thanks</TD></TR></TABLE>
You can cut it closer to exact if you don't want to use a lot of filler, but you have to be a much better welder to do it this way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
You can cut it closer to exact if you don't want to use a lot of filler, but you have to be a much better welder to do it this way.</TD></TR></TABLE>
yeah thats true i just welded it today. kinda sucked cause imma rookie at that. looked hella fudged. its ok, ill just have to put hella filler on that sucka. it looks ok shapewise. i guess im goona be ok with it..
graveltravel
Sep 30, 2005 03:08 PM
