Honda S2000 Honda S2000
SEARCHED: failed !!!!! .......Help Needed !! tranny fluid ??? maybe >????
Old Mar 2, 2005 | 09:00 AM
JusT a Cx's Avatar
Default SEARCHED: failed !!!!! .......Help Needed !! tranny fluid ??? maybe >????
i have a 00 s2k with only 18g miles.. its mint but i noticed shifting into 3rd or 4th gear it feels lil notchy when shifting?? but the clutch is perfectly fine grabs and everything i have no clue what it could be..i seen the 00-01 have some sorta tsb 54 clutch problem or something .. do u know anything about this.... like when shifting its not grinding or anything its just got a ruff lil feel to it sometmes .. its just not as smooth as 1st to 2nd 4th to 5th, 5hth - 6th ...n so on... im thinking new tranny fluid or something ? i had bought the car of an older gentle men and hes had it serviced threw honda an i have all the papers...car was well maintained.. passes the inspection and everything... i just dont know if this is an anoyying problem with this yr s2k or something i should be worried about ?? any input would be awsome
Old Mar 2, 2005 | 09:23 AM
Atheist's Avatar
I would start with a fluid change. I have no clue on TSBs
Old Mar 2, 2005 | 09:29 AM
Nishant's Avatar
Default Re: (Atheist)
replace your tranny and clutch fluid...just cause its 18k miles it does not mean its still good, it wears out over time
Old Mar 2, 2005 | 09:30 AM
JusT a Cx's Avatar
Default Re: (Nishant)
im gonna do that right away..... does that sound right about curing the problem you think ? what brand of fluids do you guys recc using ??
Old Mar 2, 2005 | 01:20 PM
Nishant's Avatar
Default Re: (JusT a Cx)
Tranny = i use redline fluid
Clutch = ATE SuperBlue....same as my brake fluid (might as well change that, you're supposed to every 3 yrs)
Differential = LE-607
most of this stuff you can buy from http://www.hardtopguy.com call jeff, he will take care of you. tell him i sent ya
Old Mar 2, 2005 | 05:43 PM
JusT a Cx's Avatar
thanks bro i appreciate it
sunnydelight
Honda S2000
Apr 7, 2008 06:10 PM
BlackLudeSR
Jun 21, 2007 01:50 PM
phoshizzle88
May 17, 2006 10:39 PM
AP1
Honda S2000
May 15, 2006 09:44 AM
JDM-Vic
Apr 6, 2004 01:48 PM
