What is this black crud on Cylinder Head?
Old Mar 2, 2005 | 07:42 AM
T-RO's Avatar
Default What is this black crud on Cylinder Head?
Well somethign recently broke on my boosted D16z6. So I am in the process of replacing it. Well I pulled the valve cover off of my D16 and found this black crud all over. What is it? I can scrape it off and it crumbles when messed with so its not pieces of rod or piston right? lol
Old Mar 2, 2005 | 08:06 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: What is this black crud on Cylinder Head? (T-RO)
burnt oil, what kind of oil do you run, i would recomend using a high quality synthetic
Old Mar 2, 2005 | 08:34 AM
mike-y's Avatar
Default Re: What is this black crud on Cylinder Head? (PURPLETERROR)
yup. synthetic oils don't tend to leave residue like that.
Old Mar 2, 2005 | 08:57 AM
T-RO's Avatar
Honestly I usually run Wal-Mart 10w-30.
Old Mar 2, 2005 | 09:01 AM
EJ1 wilcox's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">Honestly I usually run Wal-Mart 10w-30. </TD></TR></TABLE>
You aren't serious are you?
That's probably why you broke something in your engine... that residue is probably all over the place in there....ewwww
Old Mar 2, 2005 | 09:13 AM
drdisco69's Avatar
Default Re: (T-RO)
Old Mar 2, 2005 | 09:54 AM
ELAMINT5's Avatar
Default Re: (drdisco69)
O wow I am sorry about the mess. Do you call your car a dirty little b*tch when drive? Walmart oil, damn you hate your car don't you. Oil is the most important thing in your motor man. GOOD LUCK
Old Mar 2, 2005 | 10:30 AM
T-RO's Avatar
lol
I've learned my lesson.
Shes getting Synthetic oil 2nd time around.
Old Mar 2, 2005 | 12:29 PM
tgreaves's Avatar
Default Re: (T-RO)
Kinda looks like someone missed a few oil changes..
Old Mar 2, 2005 | 03:01 PM
HobbesGSR's Avatar
Default Re: (tgreaves)
Yep, oil will start looking like that if left in motor for an extended period of time.
Old Mar 2, 2005 | 03:28 PM
Runnerdown's Avatar
I see that all the time it is lack of oil changes. The oil breaks down into that sludge. Unless you have owned the car for a long while its probably not your fault. It takes quite some time for that to happen.
Old Mar 2, 2005 | 04:45 PM
92HB_HB's Avatar
Default Re: (Runnerdown)
nothing wrong w/ walmart oil.. i use it in my turbo gsr... change it every 2K miles.. anf my internals look fine... slug like that is a result of neglect from oil changes..
Old Mar 3, 2005 | 03:38 PM
rice a roni's Avatar
Default Re: (92HB_HB)
lolz...when i go turbo, i planned on using synthetic. walmart oil? not good for car. lolz. its ok, you learn from your mistakes.
milkmanLCA
Oct 5, 2008 07:55 PM
kodarren
Sep 22, 2006 03:50 PM
mcgee*
42
Mar 15, 2006 10:16 AM
VTECcnIT
Dec 31, 2005 02:10 PM
ActiveAero
Aug 12, 2004 11:41 PM
