What Do These Have in Common?
Old Mar 2, 2005 | 07:40 AM
baphomet's Avatar
Default What Do These Have in Common?
Turn signals, Gauge cluster lights (cel etc.) and tach, radio power.
The reason I ask is that none of these work on my crx. It is driving me crazy trying to figure out what it is. The weird thing is that the hazards work but the individual turn signals don't.
Old Mar 2, 2005 | 08:00 AM
drdisco69's Avatar
Default Re: What Do These Have in Common? (devnull)
The hazards and the turn signals are on different power circuits from the fuse box, and have different fuses. Notice that the hazards work when the car is off and the turn signals don't.
Old Mar 4, 2005 | 07:55 AM
baphomet's Avatar
Default Re: What Do These Have in Common? (drdisco69)
bump
Old Mar 4, 2005 | 09:07 AM
1995Ex_Sedan's Avatar
Maybe pull apart the dash and start checking plugs?
David.
Bump, Btw.
Old Mar 7, 2005 | 09:05 AM
baphomet's Avatar
Default Re: (1995Ex_Sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Maybe pull apart the dash and start checking plugs?
David.
Bump, Btw.</TD></TR></TABLE>
I can't even remember how many times I did that. I just can't figure it out. And the horn worked, then it stopped, then it worked, and now it doesn't work again.
Old Mar 13, 2005 | 01:52 PM
baphomet's Avatar
Default Re: (devnull)
Any other ideas?
Old Mar 14, 2005 | 07:55 AM
baphomet's Avatar
Any relay that would cause this? It seems that the problem lies on the gauge cluter harness. The radio and clock don't get any power either and they are on the same harness as the cluster. The grounds work but no 12v at the radio.
Old Mar 15, 2005 | 07:27 AM
baphomet's Avatar
bump
Old Mar 16, 2005 | 03:07 PM
baphomet's Avatar
Old Mar 18, 2005 | 06:58 AM
baphomet's Avatar
bump
Old Mar 18, 2005 | 12:52 PM
p3lon21's Avatar
check your fuses
Old Mar 18, 2005 | 03:52 PM
baphomet's Avatar
Default Re: What Do These Have in Common? (pelon 1990 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pelon 1990 civic si &raquo;</TD></TR><TR><TD CLASS="quote">check your fuses</TD></TR></TABLE>
LOL yeah, that was obviously the first thing I checked and rechecked. ALL the fuses are good.
Old Mar 25, 2005 | 08:12 AM
baphomet's Avatar
Old Mar 25, 2005 | 11:50 PM
blacktegmd's Avatar
if your radio,tailights and dash doesnt light up or work there is a 15w fuse in the fuse box(left of the steering wheel) that needs to be replaced, my crx use to blow this all the time because of leaky taillight-housing that use to fill up and short the bulbs and the plugs out, so check for a blowen fus and replac your brake lights..
Old Mar 26, 2005 | 10:21 AM
baphomet's Avatar
Default Re: (blacktegmd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacktegmd &raquo;</TD></TR><TR><TD CLASS="quote">if your radio,tailights and dash doesnt light up or work there is a 15w fuse in the fuse box(left of the steering wheel) that needs to be replaced, my crx use to blow this all the time because of leaky taillight-housing that use to fill up and short the bulbs and the plugs out, so check for a blowen fus and replac your brake lights..</TD></TR></TABLE>
The tail lights work and all the fuses are fine. It is just the turn signals, tach, and most of the lights on the cluster except the battery light, and the radio and clock.
They are all on the same small harness. I wonder if something is broken in the gauge cluster if it would cause all this. I swapped out the harness and fuse box and still nothing. Maybe I need a new gauge cluster.
Old Mar 26, 2005 | 11:27 AM
atcrx's Avatar
Did you check the box under the hood. It has some fuses in it also. Had a buddy's car the stop lights didn't work and the fuse was shot in the box under the hood.
Old Mar 26, 2005 | 03:47 PM
baphomet's Avatar
Default Re: (atcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you check the box under the hood. It has some fuses in it also. Had a buddy's car the stop lights didn't work and the fuse was shot in the box under the hood.</TD></TR></TABLE>
Yes, all the fuses (under the dash and under the hood) are fine.
bdavis
15
Oct 9, 2017 12:11 AM
vteck1ck
12
Feb 17, 2010 08:04 AM
riceboy
Mar 21, 2005 01:07 AM
Ej1_coupe
Sep 26, 2004 06:39 AM
RedDelSol si
18
Apr 21, 2004 09:11 PM
