Engine Management questions
Old Mar 2, 2005 | 05:10 AM
H22A1allmotor's Avatar
Default Engine Management questions
I have an H22A1 i am building with mahle 11.5:1 oversize pistons and eagle rods. I am using stage 3 crower camshafts and crower valves and dual springs and retainers. I am making and induvidual throttle body set-up and eliminating the balance shafts as well. All i have as far as fuel managment right now is an apexi V-AFC, I know i will need more than this but i am wondering what you guys might recomend as a good tuning system. I am not looking to go all out and buy an AEM EMS but I am willing to spend around 600-700$. Let me know what products you guys have had success with and where to buy them at. thanks so much for me out!
-Aaron-
Old Mar 2, 2005 | 05:25 AM
Dougs96SI's Avatar
Default Re: Engine Management questions (H22A1allmotor)
If you are OBDI, most people would recommend tuning with Hondata, or Uberdata. If you arent OBDI you should buy the conversion harness, and tune with one of those two. (Im guessing that you are OBDI since your name is H22A1, which is fourth gen)
Old Mar 2, 2005 | 06:16 AM
bad-monkey's Avatar
hondata/uberdata.
Old Mar 2, 2005 | 10:17 AM
ChrisRicketts's Avatar
Default Re: (bad-monkey)
Hondata = the best system money can buy.
Uberdata = the best system money can't buy.
Old Mar 2, 2005 | 09:49 PM
so would you recomend an s200 system? and then i would also need datalogging capability so i could tune it myself and possibly even the ROM editor V3 so that i could tuen the system through the computor if the local dyno does not already have this available.
So i am looking at about 295+250 so roughly 600 to 700 dollars after i run it on the dyno right? would you say this is right? i have never done this before so i have no idea how to tune if it is easy or what to do once i get there, i mean wont i need a wideband O2 sensor? thank you for taking the time to answer my first questions please try and help me on these.
-Aaron-
Old Mar 2, 2005 | 10:46 PM
98vtec's Avatar
moderator emeritus
Default Re: (H22A1allmotor)
if your gonna be running ITB's i would rather get AEM EMS. You can find them used sometimes for like 600-700 bux.
ITB's take a lot of tuning and i think only standalone would do it the best.
Old May 18, 2005 | 03:34 PM
SilverPanda's Avatar
Default Re: (98vtec)
ok right now i have a CAI, headers, and im going to get some crower stage 2 cams and new springs and retainers. so do i need to get hondata and if i do which one do i get? the s100 or 200 or whatever one? how much do they run. oh yeah i have an h22a4
Old May 18, 2005 | 03:49 PM
prelittlelude's Avatar
Default Re: (vtech22)
if thats as far as your going to go just pick up a used vafc to add some extra fuel and pull it where needed
Old May 18, 2005 | 04:20 PM
Default Re: (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">if thats as far as your going to go just pick up a used vafc to add some extra fuel and pull it where needed</TD></TR></TABLE>
sorry im pretty new at this but what is a vafc and what do you mean add some extra fuel and pull it where needed?
Old May 18, 2005 | 05:22 PM
H22Si's Avatar
uberdata
http://www.pgmfi.org
http://www.uberdata.org
Old May 18, 2005 | 10:24 PM
4LugR's Avatar
Default Re: Engine Management questions (H22Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 &raquo;</TD></TR><TR><TD CLASS="quote">
sorry im pretty new at this but what is a vafc and what do you mean add some extra fuel and pull it where needed?</TD></TR></TABLE>
http://www.apexi-usa.com/produ...Num=1
i have a V-AFC, and its great, wen its tuned.. u can select points on ur RPM band, which u can manually adjust the fuel flow, increasing it or decreasing it as needed. for more info, search on it, lots of threads dedicated to the V-AFC
Old May 19, 2005 | 08:02 AM
Default Re: Engine Management questions (AEMPrelude916)
http://www.group5motorsport.co...lVAFC
is this a good price for one?
Old May 19, 2005 | 08:12 AM
4LugR's Avatar
Default Re: Engine Management questions (vtech22)
thats cheap for a new one, but if u look on ebay, u could find one for a lot cheaper. i got mine for 150.
Old May 19, 2005 | 08:37 AM
VSBB6's Avatar
AEM EMS gets my vote, its user friendly and you have total control over the motor.
Im running it with TWM ITBs.
Old May 20, 2005 | 07:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEMPrelude916 &raquo;</TD></TR><TR><TD CLASS="quote">thats cheap for a new one, but if u look on ebay, u could find one for a lot cheaper. i got mine for 150.</TD></TR></TABLE>
alright cool ill start looking, and then also is 150 an hour a good price to tune a vafc?
Old May 20, 2005 | 08:10 AM
4LugR's Avatar
depending on the dyno prices in ur area, over here where i live ther 125 and hour. so depending on the other dyno's in ur area, call around and check
93delslow315
Engine Management and Tuning
Dec 11, 2010 06:08 PM
JiGGaPiNNo
Aug 31, 2005 10:43 AM
k_bster24
13
Apr 9, 2004 06:51 AM
Boostless97Lude
Jul 20, 2002 10:24 AM
93B17A
Mar 20, 2002 12:25 PM
