3" Exhaust on CRX
Hi!
Anybody that has made a 3" exhaust for a CRX... i made mine yesterday and it got very low
, went under the the fuel tank and the lower control arm. Using 2 60 degrees bends, 1 15deg, and 1 30degress.
I have made the same system for couple of others CRX's but with 2,5" and it's has bean quite good, but with 3" it got f***'
Anybody that has made a good 3" system? How, what bends?
Modified by YASH at 2:19 PM 3/2/2005
, went under the the fuel tank and the lower control arm. Using 2 60 degrees bends, 1 15deg, and 1 30degress.I have made the same system for couple of others CRX's but with 2,5" and it's has bean quite good, but with 3" it got f***'
3" over the control arm are very thight.....and if i go the stock way i cant use a N1 style muffler.
Any pictures of the therma systems?
Modified by YASH at 2:37 PM 3/2/2005
thermal is just like KTeller 3" CRX exhaust difference is Thermal has the 4" round midpipe canister/resonator before the first bend from cat.
stock routed.
if i ever run exhuast straight out it will be 3" from cat-back. under gas tank.. under brace where tie bar.. and under spare well with the hks style dual tip muffler from x3 sticking right out angled 15-30* up. all piping painted with rust protection and painted flat black.
2006 Si concept. with exhaust coming out center.
stock routed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner »</TD></TR><TR><TD CLASS="quote">thermal is just like KTeller 3" CRX exhaust difference is Thermal has the 4" round midpipe canister/resonator before the first bend from cat.
stock routed.
I've made my exhaust of stainless steel, here is a picture when i had it with 2,5" but now i i have remade it to 3" cuz i've got a 3" Dp. And the rout is exactly like you say. But if I lower my coilis more it will get f****
stock routed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi »</TD></TR><TR><TD CLASS="quote">why cant you use an n1 muffler, im using an n1 muffler.</TD></TR></TABLE>
the N1 muffler is to long and will get to long out from the bumper..if you take the stock route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YASH »</TD></TR><TR><TD CLASS="quote">the N1 muffler is to long and will get to long out from the bumper..if you take the stock route.</TD></TR></TABLE>
oh really? mine only sticks out about an inch or so, not noticeable, and not gross,
Modified by slowpokesi at 11:28 AM 3/2/2005
I love that white crx..So damn clean..
If you look though the guy from sweden's n1 is alot bigger and longer..Shoudnt have gotten such a big muffler to begin with..
Nice..you've got any pictures from below
But like Mr.speaker my N1 muffler is i think a bit longer...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YASH »</TD></TR><TR><TD CLASS="quote">Nice..you've got any pictures from below
But like Mr.speaker my N1 muffler is i think a bit longer...</TD></TR></TABLE>
i'm sure it muffles the noise better and deeper with it being bigger. then the n1.
i dont like the way slowpokesi exhaust looks.
Thats the knock off n1 muffler, its 18 inches long im positive that its the same as the regular n1
whats not to like about it, you either like the n1 mufflers or you dont. I like it, I like the way it sounds, when it was na and it sounds even better with boost
maybe its just the pics.. it just doesnt look positioned right. and the bling from the exhaust pipe sideways. but im sure you like the way it looks cause you wouldnt of done it in the first place.
tbtw here is mine..
tbtw here is mine..
well, i have a stock bumper, i think its retarded when people posisition the mufflers so that it comes out the wrong side of the car,
diffrent strokes for diffrent folks, there isnt any bling from the pipe going across, the car is slammed so unless your laying on the ground looking or unless your about 50 feet back its not really that visible.
I have often pondered this dilemna.....
Solution: cut out spare tire well and make it flush with the trunk are (new sheetmetal).
Then you'll have plenty of room for the exhaust to straight through the tunnel and room for the can too.....
Cons: must use fuel cell and you lose spare tire storage.
pro's: shorter, straighter exhaust path
My solution was to take only 1 turn in the exhaust tunnel and exit in front of the passenger's side rear tire. No can. 2 inline resonated sections.
pics:
http://www.we-todd-did-racing....D.jpg
I only have 2.5" piping, but there's no reason 3" wouldn't work the exact same way..... and turbo is definitely quieter than my allmotor bizzle...
Alternatively, you could have a thermal 3" exhaust with that weird sideways can in similar configuration as stock and if you're concerned about exhaust path flow - add a cutout to the downpipe.....
pics:
baller alert
5 lug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
pics:
Alternatively, you could have a thermal 3" exhaust with that weird sideways can in similar configuration as stock and if you're concerned about exhaust path flow - add a cutout to the downpipe..... </TD></TR></TABLE>
5 lug.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
pics:
and look at that ground clearance
screw having an exhaust running under there. youll be dragging it all over the place. have fun with speed bumps lol.
btw, slowpoke, your si rims are on backwards
hehe i dont have the black wheels either
https://honda-tech.com/zerothread?id=1166677
Modified by slowpokesi at 4:55 PM 3/2/2005
rioninja
14
Aug 16, 2001 12:59 PM
