Throttle Boddy? Can you go too big?
Old Mar 1, 2005 | 08:37 PM
ITRacer121's Avatar
Default Throttle Boddy? Can you go too big?
I was wondering if it would hurt your performance if you go too big with an aftermarket throttle body? I have a 1.8 now but plan on 2.0 in the future and dont want to buy 2 TBs if I dont have to but dont want to loose horse power either
TIA
Old Mar 1, 2005 | 10:00 PM
NJIN BUILDR's Avatar
Default Re: Throttle Boddy? Can you go too big? (ITRacer121)
You can go to big.Not so much power wise but drivablity suffers.I don't see the need for anything bigger than the stock gsr one on something street driven.There are turboed engines making close to 600hp with a gsr tb.
Glenn
Old Mar 2, 2005 | 04:39 AM
1 2 NV's Avatar
Default Re: Throttle Boddy? Can you go too big? (NJIN BUILDR)
uhhh...........i dunno if u noticed but we are in the all motor section here, not the FI section.
Old Mar 2, 2005 | 09:05 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Throttle Boddy? Can you go too big? (1 2 NV)
Yes, you can go too big. If you get a larger throttle body you need to make sure the Intake manifold it port matched to that TB.
Old Mar 2, 2005 | 02:28 PM
Just an example that the tb isn't a big restriction in air flow.I thought about the turbo reference and was hoping no one called me out on it.
Glenn
Old Mar 2, 2005 | 02:35 PM
tonezilla's Avatar
does the same thing apply with intakes as well ? i dont know the exact specs of my throttle body, but say if it was 2.75", would a 3" intake be too big ?
Old Mar 2, 2005 | 02:49 PM
Default Re: Throttle Boddy? Can you go too big? (redxalien)
The intake tube size (between the air filter and tb) isn't as sensitive to diameter as the td is.The length and shape has tuning benefits but won't cause drivablity issues like a huge tb will.
Glenn
Old Mar 2, 2005 | 03:42 PM
Deetz's Avatar
Crazy Honda Guy
I'm running a STR 68mm TB on a B18C5, makes 4-5 hp at the wheels. I wouldn't go anything larger than that though. If its too large, you can get idle problems.
Old Mar 2, 2005 | 03:58 PM
DIFFUT'S INC.'s Avatar
Default Re: (Deetz)
im useing STR 70mm here
Old Mar 4, 2005 | 10:54 AM
ITRacer121's Avatar
just picked up a STR 70mm so we shall see what happens.
even if it doesnt help it is SUPER BLING!
BoltonGSR
Dec 7, 2006 12:15 AM
allnaturalb16
Sep 26, 2006 02:09 PM
fliP
Dec 30, 2004 10:28 AM
dohc-nyne
Apr 29, 2003 07:28 PM
StinkyTofu
Apr 21, 2003 08:38 PM
