'95 gsr stock motor into a '95 hatchback cx
can anyone please help me...everything is in place...and my motor still wont start...wat all do i need to do still...will the gsr motor harness work for the cx...where can i get a hold of diagrams for wiring conversions '95 gsr into the hatchback cx...thank you...
I also have this combination, no probs installing with the stock cx harness, but I believe the gsr harness should work as well, oh yeah with the cx harness you have to add a few wires. vtec, butterflies, knock etc.
im using a gsr ecu and harness...i do have fuel and sparks...i've changed out distributors plenty of times...and still my cx doesnt have fire or want to start...the car does crank...but wont give life...
...i do thank you for helping...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fckmnky69 »</TD></TR><TR><TD CLASS="quote">im using a gsr ecu and harness...i do have fuel and sparks...i've changed out distributors plenty of times...and still my cx doesnt have fire or want to start...the car does crank...but wont give life...
...i do thank you for helping...</TD></TR></TABLE>
Even though you are using the GSR harness, you still need to add wiring on the chassis side for the VTEC solenoid, VTEC pressure switch, Knock sensor, IAB, and 4 wire O2. Even if you haven't done any of this wiring the car should still start up and run. Check your grounds, check the timing, look over the harness and make sure everything is plugged in properly. Are you getting a CEL after trying to start it?
...i do thank you for helping...</TD></TR></TABLE>Even though you are using the GSR harness, you still need to add wiring on the chassis side for the VTEC solenoid, VTEC pressure switch, Knock sensor, IAB, and 4 wire O2. Even if you haven't done any of this wiring the car should still start up and run. Check your grounds, check the timing, look over the harness and make sure everything is plugged in properly. Are you getting a CEL after trying to start it?
RC_Benjamin
Mar 14, 2006 05:44 PM
fckmnky69
Mar 4, 2005 09:50 PM
boostedcivicsir
Sep 7, 2003 08:27 PM
