ARP rod bolts?
Old Mar 1, 2005 | 06:48 PM
cal_'s Avatar
Default ARP rod bolts?
Does arp make rod bolts for the h22? Ive tried their website but its not working correctly. I know they make them for D and B series engines, but would the bolts be interchangable from different series engines. I would think not but im not 100% sure. Anyone know?
Old Mar 1, 2005 | 07:03 PM
Drag-Accord's Avatar
Default Re: ARP rod bolts? (gsr778)
If you buy eagle rods, they come with the arp rod bolts already in them.
were you planning on putting the arp's in your stock rods?? lol
Old Mar 1, 2005 | 07:12 PM
cal_'s Avatar
Default Re: ARP rod bolts? (93BoostedAcclude)
umm yeah i was planning on doing that. Im not running boost and im not getting to crazy on my all motor setup. So i figured that stock rods will be fine to run. Just wanted to get arp bolts for added assurance.
Old Mar 2, 2005 | 02:32 PM
THEUSED's Avatar
93BoostedAcclude for All Motor setups this is VERY common to just run some ARP rod bolts instead of running aftermarket rods which would be overkill, so keep you foolish opinions to yourself
Old Mar 2, 2005 | 04:58 PM
urbanlegend21's Avatar
New User
Default Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">93BoostedAcclude for All Motor setups this is VERY common to just run some ARP rod bolts instead of running aftermarket rods which would be overkill, so keep you foolish opinions to yourself</TD></TR></TABLE>
yeap
Old Mar 2, 2005 | 05:04 PM
jackstands's Avatar
Default Re: (urbanlegend21)
I don't know if ARP rod bolts are necessary, does anyone have the tensile strength specs of both? There are guys on this board that have 215-220 whps with stock bottom ends.
Old Mar 2, 2005 | 06:05 PM
cal_'s Avatar
Default Re: (jackstands)
does anyone know where i can get some arp rod bolts?
Old Mar 3, 2005 | 03:36 AM
THEUSED's Avatar
Default Re: (gsr778)
Its just some good insurance for your bottom end
http://shopping.lightningmotor....html
Old Mar 3, 2005 | 03:53 AM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackstands &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if ARP rod bolts are necessary, does anyone have the tensile strength specs of both? There are guys on this board that have 215-220 whps with stock bottom ends. </TD></TR></TABLE>
you can never be too safe and have too much insurance.
Old Mar 3, 2005 | 04:09 AM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Its just some good insurance for your bottom end
http://shopping.lightningmotor....html </TD></TR></TABLE>
these would fit on h series rods?
Old Mar 3, 2005 | 04:27 AM
THEUSED's Avatar
Oh my bad Im in B Series Mode, I going to say no, I not quite sure they make them for H Series, check out ARPs site they'll know of somewhere to get them if they do make them
Old Mar 3, 2005 | 10:17 AM
cal_'s Avatar
Well i just called arp and they dont make rod bolts for the h22, and the guy i talked to didnt know where i could get some. Anyone now where i can get some after market rod bolts?
Old Mar 4, 2005 | 05:50 PM
cal_'s Avatar
anyone? or will stock rod bolts be just fine?
Old Mar 4, 2005 | 06:19 PM
fastludeh22's Avatar
do b's use bolts...i think h's use studs on stock rods, i dont mess w/stock much....maybe get the stock rods w/studs and nuts cryo'd
Old Mar 4, 2005 | 09:02 PM
edulerp97's Avatar
Default Re: (fastludeh22)
Just buy aftermarket rods with the arp bolts in them..Like someone said never can have to much insurance.......
neyrod
Feb 16, 2005 11:05 AM
scUba-stEve
Aug 13, 2004 03:40 PM
turbociv
Sep 8, 2003 05:41 AM
Drag R
Jun 14, 2003 07:54 AM
Mover
Nov 14, 2002 11:10 AM
