wheel stud install ... help needed
could someone,anyone just give me a few pointers on how to install wheelstuds on all four corners of my 90 si hatch. i have some skunk2 extended wheel studs lying around and i wanted to put them on when my car got out of the shop. any help would be appreciated. thanks.
Rears = remove hib carrier.
Front = split hub bearing apart, or better yet replace the hub with a new one.
Also replace wheel bearings in the front knuckles. Front hubs are something like $140/ea? and wheel bearings are $40/ea. If you try to reuse your old hubs, you potentially have a chance of spinning the studs, when removing lugnuts, inside the hub and will have to replace the hub anyways and the stud.
ef90b16
Nov 28, 2008 09:36 PM
