5th Gen adj. upper control arms...
Old Mar 1, 2005 | 05:21 PM
rudeman85's Avatar
Default 5th Gen adj. upper control arms...
guys, I KNOW THEY"RE out there. I think Intrax makes them. I cannot find that damn post that talked about them though. I'm having the clearance problem that everyone else is having. I think if i got them that it would solve a lot of the issue. Anybody ever use them? Thanks!
Old Mar 2, 2005 | 04:25 AM
rudeman85's Avatar
Default Re: 5th Gen adj. upper control arms... (rudeman85)
nobody knowsss????
Old Mar 2, 2005 | 06:45 AM
LordAccord's Avatar
Sorry, I've never seen them for the accord, if intrax makes them then someone is an idiot in their marketing department, because they would be the top seller for camber correction in accords just because of all the clearance issues.
Old Mar 2, 2005 | 07:30 AM
azian21485's Avatar
i made a post about these before...one company makes them...i don't trust them though since the site is marketed for the air rides and bs like that...but here you go
http://www.truckn-store.com/pr...=1833
Old Mar 3, 2005 | 01:25 PM
rudeman85's Avatar
Default Re: 5th Gen adj. upper control arms... (azian21485)
yeah i think you were the one azian.... So your not so sure about these??? Their website says they are the ones who make them. Hmmm I'm not sure myself, But geez oh man, why doesn't anybody else make them? It's not like it should be that hard!!!
Old Mar 3, 2005 | 01:32 PM
SPEED FoRCE's Avatar
what issues are you exactly having? I might be able to give some suspension/steering advice.
Old Mar 3, 2005 | 02:31 PM
sj993's Avatar
Interesting how they say they make them. Sounds like BS to me.
Old Mar 3, 2005 | 05:20 PM
rudeman85's Avatar
Default Re: 5th Gen adj. upper control arms... (sj993)
well I have tokico RAK-501 full adjustable coil-overs. They're for race use, so they say... But anyways, I have my settings in front on 4 out 5...5 being the stiffest. But when i hit a good bump the top of my upper control arm (actually the nut on my adjustable ball joint camber kit) hits the upper wheel well. I would think if i got these UCAs that would resolve some clearance issues making it travel a little farther....hm
Old Mar 3, 2005 | 08:45 PM
azian21485's Avatar
the upper control arms i showed you might be golden...but then they might suck ***...all i know is i'm not willing to dish out that kind of money on an unproven product made by a company that sells "low ride coilovers" and **** lol
another thing i just remembered is i emailed their service rep a few times...i asked him if the kit can actually increase negative camber (what i was looking for and hardly anybody makes) and the guy kept telling me "these can correct up to 6 degrees" and wouldn't give me a straight answer...oh well...but if you wanna try it let us know how it goes...you never know you might be the first to discover a good thing
dunno how the ball joint kits work, but giving yourself a little negative camber might lower your control arm a bit...running -1 to -2 degrees isn't going to do any harm as long as your toe is within specs
as of now the only other company i know of that's making an adjustable upper control arm is fushigimotorsports...or fushigiracing...something like that but they are a sponsor on cb7tuner.com ....we'll see how theirs go but seeing as they don't make ricey stuff it might be a pretty good item
Old Mar 4, 2005 | 07:15 AM
rudeman85's Avatar
thanks a lot bro! I'm interested in them a lot, but like you said, who knows the quality..... You would think by now some company would have designed something to fix all the accords clearance issues.
Old Mar 4, 2005 | 09:43 AM
azian21485's Avatar
oh i forgot ingalls is also designing a new front camber kit...i'm not sure if it's an upper control arm or a redisgned a-arm type kit...and i'm not sure what gen they are making it for...it's on their website though
so the companies you should be looking out for new kits are ingalls and fushigimotorsports
Old Mar 4, 2005 | 10:03 AM
iam7head's Avatar
you might and might not slove the clearance issue with a camber kit.
looks like you have too little damper travel to begin with, like i said before camber kit sometime give you more headache than good.
if the car is build for full-race/track purpose, what are the chance for it to hit speed bump and such? just curious
Old Mar 4, 2005 | 01:25 PM
rudeman85's Avatar
Default Re: 5th Gen adj. upper control arms... (iam7head)
Very true, I believe that is the intent of them. But the ride quality is unbelievable!!! I think that the rate on the springs are actually softer, guessing that would be better for on the track. I would honeslty think that if I changed the camber kit it would drastically help...
Halo
May 20, 2009 02:24 PM
TraKtioN
Dec 28, 2007 02:43 AM
c mak
Sep 13, 2004 04:51 AM
905_Legend
May 15, 2003 09:55 PM
