Clicking noise?
Old Mar 1, 2005 | 05:08 PM
Los.'s Avatar
Default Clicking noise?
hello everyone i have a 88 crx si and its been like 2 months since i herd this anoying noise coming for sure in the rear right side of my car, only when im driving i hear a click click click click click and at first i thought it was the wheel bearings but my friends told me they would make a grinding loud noise so i rulled that out which now im trying to think what could it be, everything looks fine, i know just a noise could be anything and this post probably sounds stupid but i was curious if anyone else had some wierd noise like i do
Old Mar 1, 2005 | 05:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Clicking noise? (crxkid88Sir)
Probably an axle...
that would be my quess..
Old Mar 1, 2005 | 05:30 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Clicking noise? (88DXCRX)
i vote axle as well. is it especially pronounced when you go around a corner? cause if it is.. then axle..
Old Mar 1, 2005 | 05:32 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkid88Sir &raquo;</TD></TR><TR><TD CLASS="quote"> rear right side of my car, </TD></TR></TABLE>
Axle in the rear of a FWD?
Hmmm.. Id check to make sure your breaks are good?
Old Mar 1, 2005 | 08:27 PM
Los.'s Avatar
Default Re: Clicking noise? (HamiltonRex)
i just replaced the brakes all around the car about 2 weeks ago new rotors and pads so i dont know i herd it could be my susp in a way since its old something could be lose and just click i danno
Old Mar 1, 2005 | 09:32 PM
boosted_hatch_216's Avatar
did you make sure everything was tight?
Old Mar 1, 2005 | 10:57 PM
143MYVTECEF's Avatar
Default Re: Clicking noise? (boosted_hatch_216)
Do you have Drum or Disc rear brakes?
Old Mar 2, 2005 | 05:04 AM
GoFastTshirts.com's Avatar
make sure you don't have anything wedged in your tire
Old Mar 2, 2005 | 08:31 AM
EP3_05's Avatar
Check your tires for any lodged stones. Check to make sure the tires are inflated properly. It still could be a wheel bearing. I just replaced mine in the front and it was bad but it did not make any noise so who knows. The bearing was shot so much that there was almost 3/4" of play in it. Also check the suspension adn make sure everything is tight and not binding on anything.
Old Mar 2, 2005 | 10:01 AM
Los.'s Avatar
Default Re: Clicking noise? (91civic)
i was thinking it still could be the bearings cause the car does feel alittle harder to cruise even though it doesnt make a grinding noise
Apple395
May 28, 2015 10:09 AM
lopezchris21
14
Aug 10, 2008 06:57 PM
BLK99VTECR
Nov 10, 2003 01:16 PM
td04civic
Feb 6, 2002 05:44 AM
