Opinions on Apexi N1 dampers vs. Mugen Nzero
Old Jan 21, 2002 | 09:22 AM
typer906's Avatar
New User
Default Opinions on Apexi N1 dampers vs. Mugen Nzero
I have had a order in for some Mugen N0 dampers for about three months now and am getting tired of waiting. I can have the Apexi N1's pretty quickly but how do they compare? Should I wait it out or what?
Old Jan 21, 2002 | 10:32 AM
Mario's Avatar
Default Re: Opinions on Apexi N1 dampers vs. Mugen Nzero (typer906)
Which Apexi N1 damper are you reffering to? There are quite a few models, each with different specs. If you are thinking of the 99 Spec N1 (which is the most commonly seen model being sold by private parties), then without a doubt the Mugen is better. The Type Pro Spec N1, is a little better but also alot more expensive, almost Mugen price. Then you have the 2000 Spec N1, with the huge 52mm piston...that's real expensive and I haven't seen them in the states yet.
In any case I believe EPGONZALEZ had the Apexi N1 99 spec on his ITR, now he has the Mugen (N-1 or N-zero, i'm not sure). Hit em up for all your Mugen questions, lol.
Old Jan 21, 2002 | 11:57 AM
White Dragon's Avatar
I would hold out for the Mugen N-Zeros. I ordered mine and got them pretty quickly, that's odd that you have had to wait so long.
I had the golden opportunity to ride in Andrew's car at last year's Expo, and his car handles unreal, I was truely amazed. He has the Mugen N-1 kit. The N-Zero kit is suppose to be essentially the same with a bit softer valving so that they are tolerable on the streets. Wait for the Mugen N-Zero
Old Jan 21, 2002 | 12:58 PM
Alexis's Avatar
New User
Default Re: Opinions on Apexi N1 dampers vs. Mugen Nzero (White Dragon)
The APEXi N1's aren't as good as the MUGEN N1, but it is a lot cheaper and is a lot better than stock. It is a good setup since it could be driven in the street, as well as the track. I know many daily driven ITR's that have used them on the track with good results.
Old Jan 21, 2002 | 07:43 PM
AJ PwR's Avatar
Go Mugen Apexi
Other options like Spoon or Buddyclub or ZEALs.
Old Jan 21, 2002 | 07:48 PM
yellow blur's Avatar
Default Re: Opinions on Apexi N1 dampers vs. Mugen Nzero (AJ PwR)
and apexi is because ...
Old Jan 21, 2002 | 08:36 PM
Type-ARR's Avatar
Default Re: Opinions on Apexi N1 dampers vs. Mugen Nzero (yellow blur)
I dont know about Apexi's dampers but I know I love all their other products S-AFC, AVC-R, etc..... I think over all Apexi is high quality stuff
Old Jan 21, 2002 | 09:09 PM
Saga's Avatar
it's worth the wait.
...mugen n-zero...a rarity (EP owns one of the few....very few)
justinsouza
Sep 3, 2004 08:07 PM
Girlzcn2
Dec 10, 2003 07:13 AM
ITRacer121
May 7, 2002 10:08 PM
IGGY
Jan 5, 2002 05:35 PM
JAMESAKISS
Jan 2, 2002 01:30 AM
