have no idea what i did now
Old Mar 1, 2005 | 03:36 PM
jeffsciv23's Avatar
Default please help diagnos my problem, car died and tach goes crazy
ok here goes, i have a 99 civic ex turboed with a T3, uberdata and OBD1 conversion, 450cc injectors, and all the other stuff that goes along with a turbo.
i just got back from driving to the store and while i was coming home my car jerked real hard then died. so i coasted to a side street and checked everything out. it looked ok so i started it back up and started to linp it home because i didn't want to **** anything up until i found out why it did that. so i am driving like an old lady, shifting at 3500 or lower and i noticed that when the tack goes over 3000 it starts jumping around like crazy. i also noticed that it is idleing at or around like 500. no CEL's but yesterday fo rno reason i got a code 17. cleared it and it never came back.
any suggestions to what i fucked up now?
yesterday it was running fine.
Modified by jeffsciv23 at 7:26 PM 3/1/2005
Old Mar 1, 2005 | 06:27 PM
jeffsciv23's Avatar
Default Re: please help diagnos my problem, car died and tach goes crazy (jeffsciv23)
nobody?
Old Mar 1, 2005 | 06:56 PM
SCIVIC94's Avatar
sounds like a problem with the bottom end.good luck
Old Mar 1, 2005 | 07:41 PM
jeef84's Avatar
Bump for you.
Old Mar 1, 2005 | 07:58 PM
Soccerking3000's Avatar
Default Re: please help diagnos my problem, car died and tach goes crazy (jeef84)
how many pounds are you running? do you have a wideband and a good tune?
Old Mar 1, 2005 | 09:04 PM
jeffsciv23's Avatar
Default Re: please help diagnos my problem, car died and tach goes crazy (Soccerking3000)
i was running 7-9 psi but the most i hit today was like 4-5 on BBKA map modified to my car.
so for real you think it is in the bottom end?
i really don't need this right now. how can i start to diagnos it?
Old Mar 1, 2005 | 09:10 PM
Luserkid's Avatar
I think its distributor? What do you mean by jumping around? Usually when your tach does that its distributor/ignitor.
Old Mar 2, 2005 | 09:32 AM
jeffsciv23's Avatar
Default Re: please help diagnos my problem, car died and tach goes crazy (Luserkid)
the tach will just start to jump up and the engine isn't revving higher then about 3000 but th tach will show all the way to 7000.
Old Mar 2, 2005 | 10:29 AM
v4lu3s's Avatar
RTFM
id check the distributor out usully problems like that have soemthign to do with the ignitor.
Old Mar 2, 2005 | 10:43 AM
Sliced Beard's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a problem with the bottom end.good luck</TD></TR></TABLE>
Dude STFU if you do not know what you are talking about. Phukin n0ob.
Misinformation is the killer of all.
I would check your wiring and make sure that your grounds are tight......ESPECIALLY the ground on the Thermostat housing. If you have an aftermarket tachometer installed try disconnecting it and see what happens and make sure that you do not have any contaminants inside your distributor that could throw off your Cam Position sensor or Crank Angle Sensor which determines firing time. IT could be something as simpel as a loose piece of gasket floating around in your distributor to a problem with your ECU. Whatever the problem is I am 99% sure it is electrical.
good luck to you.
Old Mar 2, 2005 | 10:55 AM
POE's Avatar
POE
haha WTF your bottom end dude...
What is code 17? did u check that out?
Old Mar 2, 2005 | 11:25 AM
jeffsciv23's Avatar
Default Re: (POE)
code 17 is the VSS , once i reset the ecu it never came back.
i don't have an aftermarket tach but i will check the distributor.
Old Mar 2, 2005 | 12:02 PM
91' LS-VTEC's Avatar
Default Re: (jeffsciv23)
I'm thinking its a ground wire some where. With my car when the ignitor went out,the car didn't start rite back up.
Old Mar 2, 2005 | 05:49 PM
jeffsciv23's Avatar
Default Re: (91' LS-VTEC)
it was the screw on the coil had broke off somehow and was barely making a connection so i fixxed the screw.
at least i hope that was the problem, it started up just fine
Old Mar 2, 2005 | 06:00 PM
chad's Avatar
Moderator
Default Re: please help diagnos my problem, car died and tach goes crazy (SCIVIC94)
wrong....
probably you distributor taking a dump OR you blew off IC piping
Old Mar 2, 2005 | 06:04 PM
Humble1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffsciv23 &raquo;</TD></TR><TR><TD CLASS="quote">it was the screw on the coil had broke off somehow and was barely making a connection so i fixxed the screw.
at least i hope that was the problem, it started up just fine</TD></TR></TABLE>
good job. ( i hope no more problem for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a problem with the bottom end.good luck</TD></TR></TABLE>.
or maybe the botom end separated from the tranny..lol
Old Mar 2, 2005 | 06:10 PM
jeffsciv23's Avatar
Default Re: please help diagnos my problem, car died and tach goes crazy (Humble1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble1 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks.
just hope it wasn't my dizzy fluid
Old Mar 2, 2005 | 07:44 PM
SCIVIC94's Avatar
Default Re: (DirtySol)
MY COUSIN HAD THE SAME PROBLEM WITH HIS MOTOR TWO DAYS AGO.THE ROD BEARING HAD WORN DOWN TO THE THICKNESS OF A PIECE OF PAPER.THE MOVEMENT FROM PLAY WILL **** UP THE WAY THE MOTOR REVS
Old Mar 2, 2005 | 07:47 PM
Kamin's Avatar
Default Re: (SCIVIC94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">MY COUSIN HAD THE SAME PROBLEM WITH HIS MOTOR TWO DAYS AGO.THE ROD BEARING HAD WORN DOWN TO THE THICKNESS OF A PIECE OF PAPER.THE MOVEMENT FROM PLAY WILL **** UP THE WAY THE MOTOR REVS</TD></TR></TABLE>
you are an idiot, please never post again.
the bottom end has absolutley <FONT SIZE="7">NOTHING</FONT> to do with the reading of the tach other than the fact thats what is spinning and being counted. everything related to ignition and tach signal is in the distributor
so your cousin may have blown his engine but you have no idea what you are talking about.
Old Mar 2, 2005 | 07:48 PM
SCIVIC94's Avatar
PLUS JEEF84 EVEN AGREED.COULD ALSO BE A WIRING PROBLEM.COULD BE NIETHER.BUT JUST CAUSE YOU DON'T AGREE DOESN'T MEAN IT ISN'T POSSIBLY THE PROBLEM
Old Mar 2, 2005 | 07:51 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">PLUS JEEF84 EVEN AGREED.COULD ALSO BE A WIRING PROBLEM.COULD BE NIETHER.BUT JUST CAUSE YOU DON'T AGREE DOESN'T MEAN IT ISN'T POSSIBLY THE PROBLEM</TD></TR></TABLE>
he said bump?! how the **** is that agreeing with you?
and you obviously have no idea how it a tach signal works so you are WRONG. it is NOT THE PROBLEM
Old Mar 2, 2005 | 07:56 PM
mr. vang's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
and you obviously have no idea how it a tach signal works so you are WRONG. it is NOT THE PROBLEM </TD></TR></TABLE>
hahaha...LOL...
Old Mar 2, 2005 | 07:58 PM
SCIVIC94's Avatar
Default Re: (Kamin)
IF YOU SAY SO BUT IF IT were an eletrical problem why would the car jek to a stop.even if it were in gear it would still roll .it would just stop a little faster due to drag in the motor.
Old Mar 2, 2005 | 08:00 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">IF YOU SAY SO BUT IF IT were an eletrical problem why would the car jek to a stop.even if it were in gear it would still roll .it would just stop a little faster due to drag in the motor.</TD></TR></TABLE>
*smacks forehead*
i give up.
Coreyp91
Transmission & Drivetrain
Mar 4, 2017 12:43 AM
squareone206
May 16, 2009 08:03 PM
teamvirus
Jun 28, 2008 08:43 AM
burnitup
Aug 14, 2006 03:32 AM
AllMotor12s
May 24, 2004 07:12 PM
