Dyno videos of 250whp all motor FROG
here are the videos I promised you guys from the dyno a couple weeks ago ... finally figured out how to download videos from camera LOL.
This is with the bent valves in the head with 20 % leakage and all endyn motor specs. No cam gear tuning just clean a/f curve (fat arond 12.9s), JG Victor X manifold and Apex 2-3/8" exhaust.
Greg
This is of the engine by the intake side ...
http://www.gbrtuning.com/frog_...e.WMV
this is of the master tuner Ralphy at DRT doing his thing ...
http://www.gbrtuning.com/frog_dyn4_inside.WMV
Greg
can you explain the 4th gear pulls? the ratios aren't that true are they.
I mean you can dyno a car in 3rd gear and make xxx power then in 4th and you will make more due to the ratio differences.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regamaster »</TD></TR><TR><TD CLASS="quote">can you explain the 4th gear pulls? the ratios aren't that true are they.
Dyno in 4th as apposed to 3rd wil net you less whp as the ratio is closer to 1-1.
nice work greg!! the frog is back!! I remember seeing that car on hybird forums years ago. it was turbo b1bc right? well its good to see that its back! good luck with it.
Great vids!
Now we need the dyno chart.....
and you need some new motor mounts or at least some inserts! The motor leans back....leans back...leans back......
Originally Posted by Blind Fashion
wow that was quiet, any dyno charts we can drool over?
Originally Posted by RagingAngel
Great vids!
Originally Posted by Zigga
wow look at how much that motor moves
I'll try to get some stiff mounts, there are no front tranny mounts and a/c brackets on the motor .. I only used Home Depot polyurethane and filled the stock mounts and one energy suspension insert for the rear mount.
Originally Posted by 99B16Si
is that my old AEM EMS in there greg??? nice work man
Originally Posted by DIFFUT’S INC.
Ralphy he's on speed dail here
... one of the original pioneers of import racing ... he was the one that owned the Fast and the Furious line "I live my life a quarter mile at a time" ...
Originally Posted by frankenfiend 04
what motor are you running again?
Originally Posted by turbociv
if he is running a vicotr x manifold Then Ill safely assume its atleast 2.0L. I wish I could make power like that.
Originally Posted by sleeprhatch
pimp juice
Originally Posted by hayabusa160
damn simply amazing
- custom Endyn rollerwave pistons in 84.5mm bore
- 92mm Crower crank
- 0.137" Eagle LS longrod to use with 92mm crank and Endyn custom production piston
- JUN 3 cams
- compression around high 12's/low 13's
- ported head with bent valves (we're awaiting Endyn's head to return which will have their custom proprietary porting done for this setup ... so we decided not to waste time fixing this head until the new one arrives.
- AEM EMS 30-1000
- MSD 6AL ignition
- Apex WS exhaust
- fake J's intake and ebay iceman headlight scoop ... blended together
LOL I need to take videos of me driving it in the street when this stupid snow melts ...
hope englishtown opens up this weekend against the domestics ... we'll run it on street tires.
Will keep everyone posted, this is a really nice project ...
Greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">
We only dyno'd in 4th because in 3rd the tires were hopelessly spinning on the dyno ... we managed to get it to not spin in 4th ... I tell you one thing for such a heavy loaded gear this thing revs up real quick ...
Greg</TD></TR></TABLE>
Must be dope to have a car that strong. Good lick on everything from cali, rip up the east coast man.
those are sick numbers especially for the 20% leak and no cam degreeing. i was wondering when you were gonna tune with that 92mm crank
Ralphy - king of the meanest midrange
"Dyno in 4th as apposed to 3rd wil net you less whp as the ratio is closer to 1-1."
Yep 4th gear is generally considered "Direct Drive" or a 1:1 ratio where the input and output shafts become locked together...btw sick car.
nice work man
