How would you Clean This/whats causeing it???
Old Mar 1, 2005 | 03:08 PM
matto2413's Avatar
Default How would you Clean This/whats causing it???
http://www.we-todd-did-racing....D.jpg
i tried to clean it a couple of times with engine decreaser what that doesnt really help. what else could i use. does anyone have any idea how to clean that up and or how to fix it to prevent it from happening again
Old Mar 1, 2005 | 03:27 PM
virusiidx's Avatar
try carb cleaner, i got rid of all that gunk with a can.
Old Mar 1, 2005 | 03:29 PM
Danziver's Avatar
Default Re: How would you Clean This/whats causing it??? (matto2413)
I have that stuff on my engine too.
Old Mar 1, 2005 | 03:48 PM
PLAGUED_DB7's Avatar
Default Re: How would you Clean This/whats causing it??? (Danziver)
hot tank
let the engine warm up a bit turn it off shrink wrap all the elec. **** and sprak engine degreaser..worked ok on my teg...I need to do it again after all this rain and ****
Old Mar 1, 2005 | 04:03 PM
PandaBear's Avatar
Default Re: How would you Clean This/whats causing it??? (PLAGUED_DB7)
Dude, you are going to warp the block doing that.
Old Mar 1, 2005 | 04:12 PM
gsr-2nr's Avatar
Default Re: How would you Clean This/whats causing it??? (PandaBear)
simple green and a soft brush. hell or just get a rag with car wash
Old Mar 1, 2005 | 04:14 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">Dude, you are going to warp the block doing that.</TD></TR></TABLE>
I guess i'd better not drive in the rain anymore.
Old Mar 1, 2005 | 04:16 PM
AlxSiR7's Avatar
check your cam seal.. and valve cover gasket.. looks like they're leaking
Old Mar 1, 2005 | 04:27 PM
Nextelbuddy's Avatar
Default Re: How would you Clean This/whats causing it??? (AlxSiR7)
i use brake cleaner brake cleaner works wonders.
Old Mar 1, 2005 | 04:36 PM
xyooj's Avatar
I second the brake cleaner...just watch your paint.
Old Mar 1, 2005 | 05:42 PM
matto2413's Avatar
Default Re: (xyooj)
how about getting it power steamed?
Old Mar 2, 2005 | 05:35 PM
matto2413's Avatar
brake cleaner worked awesome. thanx guys.ill post a pic of it tomorrow.so you can see the difference
Old Mar 2, 2005 | 08:08 PM
calxtreme's Avatar
yeah. change a seal or gasket.
Old Mar 2, 2005 | 09:09 PM
CompanyFlow's Avatar
Laquer Thinner will remove any and all grease, but will turn your paint into water.
Old Mar 2, 2005 | 09:22 PM
dt4life's Avatar
Default Re: How would you Clean This/whats causing it??? (CompanyFlow)
How much does the dealership charge to change cam seals? Also I've seen the billet cam seals with 2 o rings. are they really any better than oem?
Old Mar 3, 2005 | 04:53 AM
AlxSiR7's Avatar
Default Re: How would you Clean This/whats causing it??? (wannaTypeR)
yes.. the billet cam seals are a lot better. oem ones crack and just do it yourself. check my thread: https://honda-tech.com/zero...age=2
Platinum.Skillz
Oct 10, 2007 11:26 AM
truevietluv636
17
May 17, 2007 03:03 PM
averyvm
12
Feb 1, 2007 08:19 PM
XHatchXcivicX
34
Jul 10, 2005 12:49 AM
EKen9
May 14, 2002 07:13 PM
