d16z head to a ZC block
Old Mar 1, 2005 | 02:40 PM
Civic1.6VTEC's Avatar
Default d16z head to a ZC block
what would you need to do to a ZC single cam block, to mate it with a d16z6 head. the motor used to be a d15b VTEC, but the oil pump took a **** and fucked up the block.
Old Mar 1, 2005 | 02:44 PM
VTECVillain's Avatar
Default Re: d16z head to a ZC block (Civic1.6VTEC)
Simply bolt the head in place just as if you were putting the Z6 head on a Z6 block.
Old Mar 1, 2005 | 02:59 PM
Default Re: d16z head to a ZC block (VTECVillain)
nothing else needed for the VTEC oil passages?
Old Mar 1, 2005 | 06:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic1.6VTEC &raquo;</TD></TR><TR><TD CLASS="quote">nothing else needed for the VTEC oil passages?</TD></TR></TABLE>
You said it was a D15B VTEC so it will be the same as a D16Z6, no changes needed. If the block was nonVTEC then you would need to remove the oil jet.
Old Mar 1, 2005 | 07:08 PM
the block is a 90-91 ZC.
blacktibby07
Jan 20, 2012 01:36 AM
importdreamer
May 26, 2008 02:24 PM
92_VX_EG
May 12, 2007 06:31 AM
Bently_Coop
Aug 23, 2006 05:37 AM
sparq
Nov 20, 2002 05:43 PM
