Tie Rod Ends
Old Mar 1, 2005 | 01:48 PM
92integraVTECgsr's Avatar
Default Tie Rod Ends
I need to change my outer tie rod ends. How hard is this? I looked through the helms manual, seem pretty simple.. I just have a question about lining up/marking the threads that go into the steering joint.. what exactly do I have to mark so the new one goes in exactly the same way??
Thanks.
Old Mar 1, 2005 | 02:48 PM
vjace's Avatar
Default Re: Tie Rod Ends (92integraVTECgsr)
it never goes in exactly try to match it up best you can and then get in alignment right after
its very easy job to do.
Old Mar 1, 2005 | 03:10 PM
IVI's Avatar
IVI
count how many times you spin them to take them off , so you can put the new one back on similarly.
as vjace said it never goes on exactly and get the alignmennt right after for a proper adjustment.
Old Mar 1, 2005 | 03:14 PM
Keno20's Avatar
Default Re: Tie Rod Ends (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">count how many times you spin them to take them off , so you can put the new one back on similarly.</TD></TR></TABLE>
follow that advise and you cant really go wrong. Pretty simple job, i did it the other week.
Old Mar 2, 2005 | 04:58 AM
JimBlake's Avatar
Default Re: Tie Rod Ends (Keno20)
You can leave the locking nut in position as a marker. But...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vjace &raquo;</TD></TR><TR><TD CLASS="quote">it never goes in exactly try to match it up best you can and then get in alignment right after.</TD></TR></TABLE>
Old Mar 2, 2005 | 05:25 AM
BolivianDc2's Avatar
you also might want to soak them in PB blaster for a couple hours before you try and take them off
Honda_Eq
10
Jan 25, 2008 11:38 AM
goldegg
Nov 3, 2007 02:35 AM
e jay one
Jan 24, 2007 10:02 AM
Nextelbuddy
Apr 25, 2005 06:57 AM
SlammedBlueEM2
Aug 4, 2004 04:45 PM
