will a gsr 96+ obd2 oil pump fit a 95 obdI gsr block
Old Mar 1, 2005 | 01:04 PM
lowbudgetracing's Avatar
Default will a gsr 96+ obd2 oil pump fit a 95 obdI gsr block
i have a 96 gsr that i put a used gsr motor in but the motor i put in does not have a crank speed flucation sensor
so i need to know if i can put the newer obd2 oil pump and sensor on my older obd1 block
Old Mar 1, 2005 | 02:43 PM
drdisco69's Avatar
Default Re: will a gsr 96+ obd2 oil pump fit a 95 obdI gsr block (lowbudgetracing)
Yes, it will fit, although you may need to trim the lower cover to get it to fit.
Old Mar 1, 2005 | 03:09 PM
DIFFUT'S INC.'s Avatar
Default Re: will a gsr 96+ obd2 oil pump fit a 95 obdI gsr block (drdisco69)
yea what he said
undagroundrican
Mar 11, 2008 04:27 PM
standinghollow
Oct 14, 2005 12:53 PM
hackish
Oct 14, 2005 11:30 AM
weraider30
Mar 7, 2005 05:34 PM
