obd1 in 97 dx. missfireing and will not idel
Old Mar 1, 2005 | 12:15 PM
DaMaCk's Avatar
Default obd1 in 97 dx. missfireing and will not idel
Ok I am a little stressed out so I may not type in correct english......
any way I have read all of the posted wireing changes for this swap and have all of them correct. I have a jumper harness I am still useing the obd-1 ecu and dist. MY problem is the car does not want to idel well. sometimes the car will idel fine and some times the motor shakes like it wants to die and sometimes it will die. When driving down the road the throttle does not respond then kicks in strong. ???? If i keep the motor reved up it will not bog but when cruseing it will bog down and not respond to the throttle. It does not show any check engine lights at any time. If I remove any sensor plugs the car will die and it will show a check engine light. So I hope that the ecu can read all of the sensor correctly.
hellcatjdm
Dec 12, 2012 10:19 AM
wfocrx
Aug 28, 2009 02:59 PM
streetcartuner
Mar 30, 2008 10:25 AM
Carpartsguy
Jul 26, 2005 10:20 AM
