Sparco seat with stock seatbelt?
I don't have sparcos, but on mine there was a place in the same spot that you just bolted the buckle to. just like the factory one. it was a direct swap.
what kind of mounting brackets are you using?
there's supposed to be mount on the seat bracket (right side if driver's side bracket, left side if passenger side bracket), which i've found to be unthreaded usually. but there's a mount there, and you find a bolt that will hold your buckle there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill »</TD></TR><TR><TD CLASS="quote">I don't have sparcos, but on mine there was a place in the same spot that you just bolted the buckle to. just like the factory one. it was a direct swap.
importdreamer
Oct 16, 2005 01:22 PM
