getting hot under the hood
i have a 95 accord ex auto tranny (soon to be 5 speed) and i replaced the rad about a year ago and the thremastat, to 160D. but when i am sitting at idle for more then 5-10 mins my temp starts to go up past half but when i am driving it stays normal right below the half point and the car drives fine starts fine heat is ok air is ok only when the car sits at idle for like 10mins does it get hot
ever here of this?
is it normal with a lower degree themastat?
or do i have a problem that i need to fix?
ever here of this?
perfectly normal.
When you're sitting there you have no air going through the radiator or past the engine to keep it cooler sooo to keep your engine cool a couple of things happen.
1. Your thermostat will open letting the hotter coolant mix with the cooler coolant and letting your engine stay at a certain temperature.
2. If that doesn't stop the heat from rising then your fan should kick on. This provides two things
a. It sucks air in through the radiator, thus cooling the radiator and the coolant inside
b. It also uses the air sucked through the radiator to blow across the engine, cooling it off.
If you're wondering why it stays cool when you're driving, it is because of the air that is going around the engine and through the radiator.
KidZr0
19
Sep 1, 2011 01:28 PM
danielblushtein
Apr 25, 2010 10:48 PM
B18EG6
Mar 22, 2003 05:31 PM
