Quick help needed - Changing axle + oil seal
Old Mar 1, 2005 | 08:27 AM
soHybridized's Avatar
Default Quick help needed - Changing axle + oil seal
I'm about to put in my new axle but I don't know which way this new oil seal goes into the tranny. The old one was pretty mangled when it popped out and I didn't see which way it goes in (DOH!). The picture in the Helms is too small to see. The seal has a spring on it, does the spring side face the tranny or the axle? TIA
Old Mar 1, 2005 | 08:49 AM
EE_Chris's Avatar
Default Re: Quick help needed - Changing axle + oil seal (TranceadikT)
When the seal is installed you should NOT be able to see the spring.
Old Mar 1, 2005 | 08:50 AM
civtegra_hybrid's Avatar
yeah the little spring goes facing in the tranny, and the flat part on the out side. the spring is what makes the seal tight around the axle for it won't leak, so don't F*** it up
Old Mar 1, 2005 | 08:51 AM
Bcuz's Avatar
The spring faces towards the trans. Make sure to lube it good around the outside to help it slide in easily. Good Luck
Old Mar 1, 2005 | 08:55 AM
thanks a lot for the quick replies fellas! back to the garage to finish the job..
jeffhoe
Dec 5, 2011 03:53 PM
pjr710
Apr 6, 2009 02:05 PM
JDM_SOHC
19
Dec 23, 2007 03:21 PM
dewoine
Apr 29, 2006 11:31 AM
JONBLAZE55555
Nov 2, 2003 01:24 PM
