Direct Port Nitrous HELP
Old Mar 1, 2005 | 08:03 AM
95accordh22a's Avatar
Default Direct Port Nitrous HELP
is direct port nitrous injection too much for a stock motor?
Old Mar 1, 2005 | 09:09 AM
tgreaves's Avatar
Default Re: Direct Port Nitrous HELP (95accordh22a)
Depends on the shot your using..
Old Mar 1, 2005 | 09:35 PM
sohc steve's Avatar
Default Re: Direct Port Nitrous HELP (tgreaves)
I agree. On a stock motor I would run a wet system so you have a fuel solenoid that comes with the nitrous system to deliver the extra fuel needed. Don't do dry unless you replace your injectors with higher flow injectors because your stock injectors will be running at a high duty cycle and fail. You don't want anything over a 50% increase in total power on a stock motor or you will kill it. There's no need for direct port on a stock motor. It's too complicated to install anyway.
Old Mar 2, 2005 | 05:50 AM
tgreaves's Avatar
Default Re: Direct Port Nitrous HELP (sohc steve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc steve &raquo;</TD></TR><TR><TD CLASS="quote">I agree. On a stock motor I would run a wet system so you have a fuel solenoid that comes with the nitrous system to deliver the extra fuel needed. Don't do dry unless you replace your injectors with higher flow injectors because your stock injectors will be running at a high duty cycle and fail. You don't want anything over a 50% increase in total power on a stock motor or you will kill it. There's no need for direct port on a stock motor. It's too complicated to install anyway. </TD></TR></TABLE>
The dry kits dont increase duty cycle, they bump up the fuel pressure to flow more fuel.. Dry kits are fine for small amounts of nitrous(55,65,75) but I wouldnt go any more than that..
#Leo#
Mar 22, 2009 08:28 AM
91integraLSVTEC
Sep 29, 2007 12:42 PM
blu2ksi
Dec 9, 2003 08:45 AM
toEknEEg
Dec 22, 2002 01:01 AM
NCSTIdriver
Oct 8, 2002 10:47 PM
