Swapping A H23 with a H22, Is this Engine Suitable ?
Old Mar 1, 2005 | 05:53 AM
OzWolfbane's Avatar
Default Swapping A H23 with a H22, Is this Engine Suitable ?
Hi,
I have a H22a going into a 1993 Prelude Si H23a1.
Now that I am close to the conversion I got a few Qs , I found a really cheap engines but a lot of the hoses and wiring is cut u know, would all my H23a1 hose/wirings just plug in except the 2 new wires (VTEC Pressure/VTEC Solenoid) just fit onto the Engine or would i Have to buy new hoses and wirings ??
Will the current A/C in the H23 work with the H22a ? coz H22a doesnt have A/C,
Anyone has a JDM H22a ECU ? I live in Australia.
Thanks
Old Mar 1, 2005 | 08:36 AM
Nikoli's Avatar
Default Re: Swapping A H23 with a H22, Is this Engine Suitable ? (OzWolfbane)
Old Mar 1, 2005 | 03:42 PM
OzWolfbane's Avatar
Error
» No Results Found
Your search for cut wires/cut hoses/engine hose returned no results.
Please try different search criteria or a different data set.
So Please can some1 help me, quick i gotta buy this engine
Old Mar 1, 2005 | 04:01 PM
The Phil's Avatar
Default Re: (OzWolfbane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Almighty Search Engine &raquo;</TD></TR><TR><TD CLASS="quote">Please try different search criteria or a different data set.</TD></TR></TABLE>
Old Mar 1, 2005 | 04:37 PM
h22mark's Avatar
Do more of a basic search like "H22 swap" so it broadens your search. Your search topic is to narrow.
Old Mar 1, 2005 | 04:38 PM
OzWolfbane's Avatar
i did ffs, if u can suggest some keywords i'll try em , i know what search is and i use it before posting thanku verymuch
i didnt try all 4 at once i just typed em together here....
Old Mar 1, 2005 | 06:19 PM
JTCdudeman's Avatar
Master H Technician
just answer his question...
Yes, the h23 wiring harness will be fine.... Yes, just add those two wires... easy to run to the ECU and easy to find with a cut harness...
OK... Now, all your hoses will transfer fine... Your A/C.. do not disconnect it.. Just ubolt it from the bracket and pull it off to the side.. This way you can Reuse it and not have to recharge it afterwards...
Old Mar 1, 2005 | 10:16 PM
9deuce9rr's Avatar
Default Re: (JTCdudeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTCdudeman &raquo;</TD></TR><TR><TD CLASS="quote">just answer his question... </TD></TR></TABLE>
i think sum people put more effort into tryin to be a smart *** with the whole "search" crap than it would take to just answer his question
Old Mar 2, 2005 | 04:37 AM
Ministry's Avatar
Default Re: (WhiteLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude &raquo;</TD></TR><TR><TD CLASS="quote">
i think sum people put more effort into tryin to be a smart *** with the whole "search" crap than it would take to just answer his question</TD></TR></TABLE>
and of course they happen to be '04s.
buy the motor if its cheap. it's hard to find secondhand motors with all the hoses and wires intact. and JDM P13 ECUs are readily available. just search
pdubble
Apr 26, 2007 11:38 AM
theoriginaljmft
Oct 16, 2006 09:08 PM
ramikassab
Dec 6, 2004 02:47 PM
RonsLude
Jul 1, 2003 10:04 PM
VRD^don
Jan 29, 2003 02:35 PM
