can vtec stay on all the time if i hook it to a flip switch
Old Mar 1, 2005 | 01:54 AM
srv3fender's Avatar
Default can vtec stay on all the time if i hook it to a flip switch
right now ive got the solenoid hook to a press button. Could i just use a flip switch. and turn it on before a run . or does it have to cut its self off
if that doesnt work
is it possible to hook it up to the pm6 si ecu and get the ecu to turn it on and off
Old Mar 1, 2005 | 04:09 AM
Deemeetree's Avatar
Electrician
DO NOT, I repeat, DO NOT mess around with your VTEC crossover point. Honda didn't program it to come on at a certain RPM for their own health. If you lower your VTEC point or keep it on ALL the time, you WILL stress out your valvetrain, wear them out quicker, have shitty gas mileage, and a shitty running car.
Leave the VTEC crossover ALONE.
Old Mar 1, 2005 | 04:23 AM
Pioneer162's Avatar
Honda does not recommend you doing that. Ford does though.
Old Mar 1, 2005 | 04:57 AM
AutoXer's Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (srv3fender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">right now ive got the solenoid hook to a press button. Could i just use a flip switch. and turn it on before a run . </TD></TR></TABLE>
You could, but you will decrease your performance. Honda spent alot of R&D time to come up with the most efficient point for the crossover. Of course, there's always the possibility that it could be improved slightly with a VAFC and tuning, but not with your button or switch. You're not helping yourself any by doing it.
Old Mar 1, 2005 | 04:59 AM
vi3t_dude's Avatar
Old Mar 1, 2005 | 05:06 AM
SE7EN3S's Avatar
Why would you want Vtech on all the time? You do understand exactly how the system works yes? At low rpm's you wouldn't want your cam in vtech mode. Kick in earlier, maybe, but not all the time.
Old Mar 1, 2005 | 05:11 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">Could i just use a flip switch. and turn it on before a run</TD></TR></TABLE>
Sure, if you want to lose . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to hook it up to the pm6 si ecu and get the ecu to turn it on and off</TD></TR></TABLE>
No, because the PM6 doesn't have any provisions for VTEC. What engine do you have?
Old Mar 1, 2005 | 05:27 AM
DohcSide's Avatar
really now well i have a vafc and i set my vtec at 3.5 each gear tunned i think is this safe?? getting me worried and ****
Old Mar 1, 2005 | 05:29 AM
Targa250R's Avatar
be professional
Default Re: can vtec stay on all the time if i hook it to a flip switch (DohcSide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">really now well i have a vafc and i set my vtec at 3.5 each gear tunned i think is this safe?? getting me worried and ****</TD></TR></TABLE>
And how did you figure out where to set the engagement point? If you say anything other than "studying dyno plots," then you're wrong.
Old Mar 1, 2005 | 05:30 AM
DohcSide's Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (Targa250R)
second thought it was tunned not by me and i hear vtec every 3.5 rpm
Old Mar 1, 2005 | 05:31 AM
BuyImports2's Avatar
isn't the point of v-tec to have cams that work well at low rpm's and then cams that work well at high rpm's? so if you only had your high rpm cam's running all the time, you would actually be hurting your performance?
Old Mar 1, 2005 | 05:32 AM
Targa250R's Avatar
be professional
Default Re: (BuyImports2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuyImports2 &raquo;</TD></TR><TR><TD CLASS="quote">isn't the point of v-tec to have cams that work well at low rpm's and then cams that work well at high rpm's? so if you only had your high rpm cam's running all the time, you would actually be hurting your performance?</TD></TR></TABLE>
Correct.
Old Mar 1, 2005 | 05:41 AM
DohcSide's Avatar
Default Re: (Targa250R)
so its unsafe? hmm new things learned
Old Mar 1, 2005 | 05:42 AM
Targa250R's Avatar
be professional
Default Re: (DohcSide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">so its unsafe? hmm new things learned</TD></TR></TABLE>
It's not unsafe - but it isn't optimal either unless it has been dyno tuned for the best proven VTEC engagement point.
It's also retarded to run a VTEC engine without a proper VTEC ECU.
Old Mar 1, 2005 | 06:05 AM
DohcSide's Avatar
hmmm kool but its better to run with the engines type ecu correct? i have a b16 running gsr ecu...
Old Mar 1, 2005 | 06:06 AM
Equilibrium's Avatar
* B A N N E D *
As you probably already know, <U>DO NOT</U> ******* ENGAGE VTEC BELOW 4400 RPM WITHOUT ANY TYPE OF TUNING; it's only going to hurt your engine and you'll see no performance gain. Vtec (Variable valve timing and electronic control) engages to open larger lobes on the camshaft to allow for deeper breathing (valve lift) supplying the engine with more oxygen as the RPM band deems it fit. You will not need it to engage any sooner as the deeper breathing is not neccessary- this concept was specifically engineered for higher rpms and I've never seen it "crack" before 4400 with significant gains. I suggest you buy a P28, P29, or P30 ecu from ebay with a skunk2 chip. You'll notice significant increases with their programming and from there you'll be able to learn and research how these EPROM chips work and control your computer and maybe some day you'll start tuning Uberdata. Or, you could buy a VAFC controller and start from there.
Here's a helpful link:
http://www.nsxprime.com/FAQ/Technical/VTEC.htm
Old Mar 1, 2005 | 06:24 AM
kyle h.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">can vtec stay on all the time if i hook it to a flip switch
you're an idiot
Old Mar 1, 2005 | 06:50 AM
Weapon_R's Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (kyle h.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">
you're an idiot </TD></TR></TABLE>
x2
Old Mar 1, 2005 | 06:58 AM
SOHC4life 96's Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (MickeyA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">can vtec stay on all the time if i hook it to a flip switch</TD></TR></TABLE>
Can you? Yes
Should you? No
Don't be stupid and **** with your VTEC unless you've spent many hours on the dyno trying to figure out what would help you the most. And I promise VTEC being on 100% of the time WILL NEVER give you best results.
FlyLO's Avatar
Don't do it man.
Old Mar 1, 2005 | 07:03 AM
ajzeg's Avatar
get a vafc you have not heard of anyone doing that for a reason
Old Mar 1, 2005 | 07:06 AM
pwrofdrm's Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (ajzeg)
Okay, my bet is on that this guy doesn't even have a VTEC engine
Old Mar 1, 2005 | 07:13 AM
ian.'s Avatar
Default Re: can vtec stay on all the time if i hook it to a flip switch (lax1185)
this is probably some of the dumbest **** ive ever heard
Old Mar 1, 2005 | 07:39 AM
bogus_ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">hmmm kool but its better to run with the engines type ecu correct? i have a b16 running gsr ecu...</TD></TR></TABLE>
you should do a search for this on ht... there are a lot of threads about why not to use a p72 on a b16. I don't get why people automatically assume that running a gsr ecu will make their b16 faster because vtec engages sooner???
Old Mar 1, 2005 | 08:13 AM
B18C2_sedan's Avatar
I agree this guy has to have a KIA or something
