If i put the A/C belt back on will i loose horespower
Old Mar 1, 2005 | 12:41 AM
srv3fender's Avatar
Default If i put the A/C belt back on will i loose horespower
i got the car with the belt off the compressor. And i love the cars quickness. But will it ruin the power just by adding the belt?
Old Mar 1, 2005 | 12:54 AM
crxnj's Avatar
Default Re: If i put the A/C belt back on will i loose horespower (srv3fender)
Your supposed to also take out the a/c system to save some weight..It doesnt make sense to have it disconnected ,but still on the motor..Its just dead weight..If you put the belt back on you wont even notice the difference..Its probably only like 1hp worth from taking the belt off the motor..
Old Mar 1, 2005 | 12:57 AM
srv3fender's Avatar
Default Re: If i put the A/C belt back on will i loose horespower (Mr.speaker)
this person swapped the engine, and never got a belt for the compressor .
Old Mar 1, 2005 | 01:00 AM
Magick211's Avatar
Yeah the only time you will notice a difference is when the compressor turned on(if the belt is on)
Modified by Magick211 at 10:37 AM 3/1/2005
Old Mar 1, 2005 | 01:16 AM
srv3fender's Avatar
Default Re: If i put the A/C belt back on will i loose horespower (Magick211)
huh?
Old Mar 1, 2005 | 01:21 AM
Magick211's Avatar
If you put the belt back on, and you decide to turn on your a/c wich engages the compressor you might notice a small hp los
Old Mar 1, 2005 | 01:24 AM
QTKEG6's Avatar
loose
Old Mar 1, 2005 | 05:18 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">i got the car with the belt off the compressor. And i love the cars quickness. But will it ruin the power just by adding the belt?
Not unless you drive around with the compressor switched on all day . . .
Draven_Von
Jul 19, 2004 06:27 AM
NoLipRacen
Mar 13, 2004 01:01 AM
chads
Jan 9, 2004 10:42 AM
speedaholic92
Sep 13, 2003 02:03 PM
Atiyeh
May 30, 2002 03:34 PM
