what cnc mill to get for making ss flanges
Old Feb 28, 2005 | 10:34 PM
RedTT's Avatar
Default what cnc mill to get for making ss flanges
we're having to buy so many flanges, our suppliers can't keep up. What is the best cnc mill to do flanges and only flanges?
Will this do? Probably not but will it at least do it at slow speed?
Old Mar 1, 2005 | 07:00 PM
SJcivic's Avatar
Default Re: what cnc mill to get for making ss flanges (RedTT)
Basic flanges can be done quiet easily on manual mills.
Rich
Old Mar 1, 2005 | 09:50 PM
NJIN BUILDR's Avatar
Its not the milling machine so much as the tooling.Any milling machine ridged enough to be used with cnc will do the job as long as high volume is not the goal.The higher end machines are going to give you more parts per hour.Not an issue unless you need to do several hundred a day.With the correct cutters and feeds/speeds stainless is no problem.
Glenn
Old Mar 3, 2005 | 07:17 AM
CRFAB04's Avatar
Default Re: what cnc mill to get for making ss flanges (NJIN BUILDR)
the mill that we use is a Mazak VTC-20B. that would work perfect for making flanges. that is what we use it for part of the time anyway. if your suppliers can't keep up with you ordering flanges, u sure wouldn't be able to keep up doing them manually. unless u have a big market for the flanges, it really wouldn't be worth buying a cnc mill. of coarse, if u r planning on producing other things then it would. any cnc mill is going to range from 60,000 and up depending on if it is a 3-axis mill or whatever.
Old Mar 4, 2005 | 03:10 PM
bjfisher's Avatar
spend 30,000 on a haas mini mill if time is a priority
Old Mar 4, 2005 | 03:18 PM
Engloid's Avatar
OG Fabricator
Default Re: (bjfisher)
Try here: https://honda-tech.com/zerothread?id=1167090
Looks like quality work from a professional shop. The thread says that stainless is comming in the future... if they had an order, they'd likely make it sooner than later.
Old Mar 4, 2005 | 03:25 PM
Fab-Works's Avatar
Default Re: (Engloid)
Yes, we can do stainless right now if you order minimum of 50. Our turn around time is very fast. give me a pm
a267mm
Welding / Fabrication
Dec 7, 2013 08:47 AM
FMN716
Oct 11, 2010 10:28 AM
89efhatch
Jan 16, 2010 12:43 PM
Nick Z32
10
Feb 12, 2009 02:02 PM
InterCooL
Jun 19, 2006 12:11 AM
