jdm gsr motor eratic idle
Old Feb 28, 2005 | 09:01 PM
jdmef-9's Avatar
Default jdm gsr motor eratic idle
ok i have a ls integra (95) has a obd1 jdm gsr motor with blox i\m and i\h\e and also it is running on a katman chipped p28 (uberdata)
but ne way i finished the swap and it idols like **** bounces from 1000-3000 or 1000-2500 that is when it is warm when it is cold it is like 2000-3500 which is inscane i cleaned the iacv did not do **** cahnged throttle bodies tried messin with the tps had no luck checked vaccum lines and i have no leaks also i have no vtec but i have no cel's until i drive the car for about 5 minutes then i get a check engine light im gonna scan it and c what it comes up with but i am wonderng if ne one else is having or had this probleme and what it was! thanks!
Old Feb 28, 2005 | 09:05 PM
Kendall's Avatar
Be sure to check to make sure there are no vacuum leaks at any of the manifold flanges either.
Old Feb 28, 2005 | 09:25 PM
B20TDC2's Avatar
Default Re: jdm gsr motor eratic idle (jdmef-9)
try your fast idle thermo valve
https://honda-tech.com/zerothread?id=1163407
read this post should help
Old Mar 1, 2005 | 05:34 AM
AlxSiR7's Avatar
sounds like the fitv to me too.. i have the jdm b18c & just had the same problem. it's under your throttle body.. take it off and becareful of the hose that goes from the iacv to the fitv.. it will spill tons of coolant everywhere if you take it off without clamping it. you probably need to tighten the fitv and youll be ok
Old Mar 1, 2005 | 07:28 AM
gser67's Avatar
i had the exact same problem and i cleaned the IAC valve PCV valve and still did nothing. so i was just checking all the vaccum lines and i found a leak what do you know. that would be my suggestion to you. check all the lines. good luck
Old Mar 1, 2005 | 09:14 AM
jdmef-9's Avatar
well i checked all the vaccum lines and no leaks they are all good i think it might be the fitv but i switched throttle bodies cuz i had an ls lying around and it did the same thing idk ill check the fitv i mean if it was a vaccum leak the check engine light would not come on so it has to be something mechanical!
Old Mar 1, 2005 | 03:55 PM
jdmef-9's Avatar
bump
Old Mar 1, 2005 | 05:30 PM
NoSwapNoCare's Avatar
in addition to vacuum leaks, chck your iacv on the back of your intake manifold might have been damaged while being shipped to you
Old Mar 2, 2005 | 09:17 AM
jdmef-9's Avatar
iacv is fine bump!!!!!!!!!!
Old Mar 2, 2005 | 09:55 AM
SoEvoL's Avatar
Default Re: (jdmef-9)
check ur FITV
Old Mar 2, 2005 | 04:14 PM
jdmef-9's Avatar
im gonna check the fitv tonight and im gonna scan it i will tell you guys what i come up with!
Old Mar 5, 2005 | 10:58 PM
jdmef-9's Avatar
well i fucked with the fitv and i had a nice 2000 rpm idle when i started it then it went right back to were it was like 10 seconds later idk w\f was up with that but i think i might mess with it some more see if i can get it right!
Old Mar 5, 2005 | 11:36 PM
adrenaline-racing's Avatar
Sounds like an intake manifold leak for sure. Use starting spray while the car is running and squirt it around the intake manifold & throttle body if at anytime it revs up quickly check it again in that area, if it does it again you found your leak. Also check all the Vac lines.
Old Mar 6, 2005 | 05:03 AM
highrevin2k's Avatar
Default Re: jdm gsr motor eratic idle (B20TDC2)
last time i saw this happen it was a leak at the i/m flange and another was on the TB from using the wrong gasket.
Old Mar 6, 2005 | 08:01 AM
FormulaGSR's Avatar
Default Re: jdm gsr motor eratic idle (highrevin2k)
with it idling and the intake tube off reac in the thottle body and plug the port it the bottom with your finger. if it idles normal and stops surging its the fitv. When i was poor i just plugged that port till i could afford a new one.
Old Mar 6, 2005 | 08:40 AM
G-bonic's Avatar
Hijacked
Default Re: (JDMCrx89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCrx89 &raquo;</TD></TR><TR><TD CLASS="quote">check ur FITV</TD></TR></TABLE>
yeah, it sounds like its ur FITV... do u get any codes ?
Old Mar 6, 2005 | 09:20 AM
swanny's Avatar
Default Re: (Stock_LS)
Did you screw the FITV all the way in? If it helped at all ******* with it, I would guess that would be the problem.
Old Mar 8, 2005 | 05:47 AM
jdmef-9's Avatar
yeah it helped and fukin vtec does not work so after like 5 minutes my check engine light goes on i think the solenoid needs cleaning but yeah idk!
Old Mar 8, 2005 | 07:18 AM
eluder33's Avatar
I had the same problem wit my prelude, try screwing the idle screw IN to lower the idle a bit, I tried all the valves and stuff and none ofit worked and it turned out to be such a simple thing like the idle screw
Old Mar 27, 2005 | 10:39 PM
derrick2237's Avatar
I had the exact same problem, this thread was a life saver
Worked like a charm
Old Mar 28, 2005 | 02:04 AM
jdm_cars's Avatar
dude, it's probably your shitty chipped P28.
I had some cold idling problems, checked everything, was driving me crazy.
Turns out it was a shitty chip burned from Uberdata for my 96 obd2 gsr running skunk2 manifold and obd1 to obd2 harness and a chipped P28.
I redid the chip with Crome, idles perfect!
I am pretty sure if you checked everything, run a stock ECU, if it idles fine, it is that shitty chip in your P28, burn another with Crome, worked for me.
For some reason Uberdata didnt work good for me, might be cause I am obd2.
If I am right, PM me back your Thanks!
OsakaGunship
Mar 1, 2011 12:13 PM
keep_up
Engine Management and Tuning
Jul 7, 2009 12:08 PM
xxi2icexx
Dec 9, 2008 07:48 AM
RedEj8
Feb 19, 2006 01:36 PM
leadfoot78
Sep 16, 2003 10:36 PM
