What valve train w/ SPoon cams?
What's up board? I did a search and couldn't find anything. SO i'm going to ask all the technicials out there. What valve train do I need so my car can safely go to 9400rpm? Is Itr good enough or should I go w/ Jun or any other compnay?
thanks
thanks
ITR is NOT good enough. Go with JUN...But i do have a question, how come you want to rev so high? The cams most likely will not be producing any power up there. Revving that high will mean your car will die faster. I'm not sure if your bottom end could handle it unless you upgraded it.
