Can someon show my how to remove spot welds?
Old Feb 28, 2005 | 08:25 PM
Race Egr's Avatar
Default Can someon show my how to remove spot welds?
I Want to see the correct way to see a spot weld removed? does anyone have before and after pictures thanks
Old Feb 28, 2005 | 08:32 PM
dustin's Avatar
Default Re: Can someon show my how to remove spot welds? (NAPIER)
Drill?
Old Feb 28, 2005 | 08:33 PM
Race Egr's Avatar
Default Re: Can someon show my how to remove spot welds? (dustin)
ok, well this is what im confused on do u drill completey through both pieces of metal or do u just tryin drill through the top layer only? also is their special drill bits u have to use? sorry to sound like a new b
Old Feb 28, 2005 | 09:15 PM
garados's Avatar
there's a special bit that has a retractable point on it. you just make a dent in the middle of the spot weld, put that point in there, the drill away. Depending on what you want to take off, it could just be the top section or you might have to drill through everything.
Old Feb 28, 2005 | 09:18 PM
Race Egr's Avatar
Default Re: Can someon show my how to remove spot welds? (garados)
well say ur removing radiator supports or firewalls or something would u just drill all the way through the spot weld?
Old Mar 1, 2005 | 12:06 AM
gldndrgn14's Avatar
you should drill all the way through the weld. if you didnt have to, how do you think that weld is supposed to hold up if it didnt penetrate through all they way? you can always spotweld it back up to fill up the whole you drilled out. thats how i was always taught anyway. either that or you got to be very carefull with a really wide flat drill bit, like a milling bit, and mill out the portion you want off. and make sure its larger than the complete weld or it will still stick. or just grind it off around the top weld with a grinder. worked well when all my bits were jacked up to redo my radiator tabs on my support.
Old Mar 1, 2005 | 07:16 AM
dwnthehatch's Avatar
Default Re: Can someon show my how to remove spot welds? (gldndrgn14)
The picture speaks for itself.
$19.99
http://www.eastwoodco.com
Item #19017
Old Mar 1, 2005 | 07:31 AM
1fastVX's Avatar
Default Re: Can someon show my how to remove spot welds? (dwnthehatch)
That is the spot weld bit I have. It works pretty good, though be careful since you will drill through both layers pretty easily. Dont ask me how I know that
John
Old Mar 1, 2005 | 09:09 AM
TurboC53_4g63T's Avatar
Thats the best tool I have ever bought for collision work.
Old Mar 1, 2005 | 09:30 AM
VRD^don's Avatar
Default Re: Can someon show my how to remove spot welds? (TurboC53_4g63T)
drill out spot weld..and use air hammer wiht a flat bit to remove what ever your removing..
Old Mar 1, 2005 | 09:35 AM
2point2's Avatar
where was this thread 2 years ago.. ?
Old Mar 1, 2005 | 09:38 AM
m R g S r's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">where was this thread 2 years ago.. ? </TD></TR></TABLE>
not in this forum. . .
Old Mar 1, 2005 | 09:41 AM
Race Egr's Avatar
Default Re: (m R g S r)
cool, thanks guys So I do drill through both layers right for radiator support removal
Old Mar 1, 2005 | 11:18 AM
1fastVX's Avatar
Default Re: (NAPIER)
No you only need to drill through the first layer of metal like in the pic above. Just be careful since it is hard to tell where the first layer stops and the second one begins. I drilled through on a few holes by accident. I found that if I seperated the metal a bit on the side with my air hammer so it was under tension when I drilled the spot weld the front layer would pop off while I was drilling. That kept me from going all the way through which is real easy to do by mistake.
John
Old Mar 1, 2005 | 01:36 PM
TouringAccord's Avatar
H-T Order of Merit
The tool I used to remove spot welds has a spring loaded tip. I make a spot in the center of the spot weld for that tip to follow then the toold just cuts arround the spot weld. It sorta looks like a small hole saw. For some reason my ImageStation pictures aren't working or I would post a picture of it.
I like the one you posted better because there is very minimal, if any, material left to grind down. The tool I use I need to grind down the rest of the spot weld but it does work good. Plus I got it for free from my moms boyfriend.
Old Mar 1, 2005 | 01:43 PM
cua0's Avatar
real men arc air spot welds out.
Old Mar 1, 2005 | 01:46 PM
H-T Order of Merit
Default Re: (cua0)
sure... if you have access to that sort of tools.
Old Mar 1, 2005 | 05:06 PM
A20A1's Avatar
I used a broad point drill bit with a drill stop on it.
But it's always easier/better when you have tools ment for the job.
Old Mar 2, 2005 | 04:50 AM
OverCenter's Avatar
Default Re: Can someon show my how to remove spot welds? (A20A1)
I have allways used a Rota Broach
http://www.toolsource.com/ost/...oogle
Old Mar 2, 2005 | 05:54 AM
DSMu4ia's Avatar
Default Re: Can someon show my how to remove spot welds? (OverCenter)
http://tinyurl.com/6kqfg
Old Mar 2, 2005 | 06:07 AM
H-T Order of Merit
Default Re: Can someon show my how to remove spot welds? (DSMu4ia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSMu4ia &raquo;</TD></TR><TR><TD CLASS="quote">http://tinyurl.com/6kqfg</TD></TR></TABLE>
The tool I use looks like that except the one I use is only one sided and has a spring loaded center point instead of a 1/8" drill bit.
Old Mar 2, 2005 | 12:29 PM
JDMCRX's Avatar
Default Re: Can someon show my how to remove spot welds? (TouringAccord)
Nice man
Old Mar 2, 2005 | 07:08 PM
SwedBoy2999's Avatar
Have you ever heard of a Blair brand spot weld drill bit. Extremely fast easy, a great tool. You should be able to pick one up at Wesco.
Old Apr 18, 2005 | 09:50 AM
90DALS's Avatar
when i replaced my core support, i used a combo of carbide tip drill bit, and a chissel
90DALS's Avatar
also, i drilled all the way through on most, all i did was re-weld the new core support from both sides. worked fine for me.
