mpfi wont start and i did search plz help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hey guys i did an mpfi swap on my 90 dx. I have a 89 d16a6 complete motor tranny ecu resister box harness dizzy etc. after i got the moter and harness in and everything hoocked up i tried to start it and it just cranks. i replaced the plugs coil cap and rotor starter battery and negative battery ground cable. i now have good spark fuel pressure is at 30 psi and the injectors are spraying/pulsing. and i have compression. i made sure that the plug wires were in the rite order according to a faq forum on this site and i made sure that the injectors were in the rite order according to the directions from a couple of sites. i also recently found out that i have a code 20 (eld) and a code 10 (air temp sensor) i fixed the code 20 by adding more grounds but its back now. also when i messed with the plug wire order i got it to kinda missfire wile trying to start and sometimes backfire. i checked all my wireing over and over the only thing i can think of is my timing but i dont know how to change that any help or if you need to know anything else jus post or you can give me a call any time at 262-510-3999 my name is phil thanks
Did you swap harnesses too? The one from the si doesn't just plug in did u know that? I mean it plugs in perfect, but the pins are in different spots, so they don't match.
You know what, from experience ( i did this last week) go over your dizzy wiring, its imperative that you get that right. And this might sound odd, but one of the first times that I hooked everything up, I was also throwing code 10 -iat, but later I went over it, fixxed b10 and codes went away, then proceeded to redo dizzy wires, and I had like 3 mixed up. I had to match colors and stuff, but anyway, it started right up. Anyway, go over wiring, sometimes, you won't even throw a code (thats obd0 i guess
yeah i did switch the harness. and thanks for the info ill check the b10 and the dizzy wiring. but if the dizzy wiring was wrong would i still have spark or could that mess up the spark order
For code 20, this is working from memory - the ELD is detected through a different place in the 88/89 models then the 90/91 models and it has something to do with the fusebox. Sorry about it being so vague, but its 4 in the morning and I'm slaving over Calc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">For code 20, this is working from memory - the ELD is detected through a different place in the 88/89 models then the 90/91 models and it has something to do with the fusebox. Sorry about it being so vague, but its 4 in the morning and I'm slaving over Calc.</TD></TR></TABLE>
i did try switching the fuse boxes but that didnt work and im not sure where the eld is but thanks for the info
still wont start someone come too my house and help me cuz im broke as hell and cant afford profesional help
i will prbably just part my car out si interior d16a6 si tranny and shell and si seat have no rips just testing water though so lets see what kinda offers u got
G. Man
15
Apr 8, 2011 08:06 AM
UNDER PRESSURE
Oct 23, 2007 12:34 PM
CimorelliCRX
31
May 17, 2004 06:13 AM
