spark plug help! nasty deposits only 1 plug
only cyl. 3 looks like this. what is the cause?? car runs like a champ. comp. test had cyl. 3 at 189 all the rest 197...I am planing on turbo should I worry? thanks for the help
nah..it dont smoke at all..and doesnt go down between changes.>>Thats the first thing I ruled out...2nd was maybe additives...I used that fuel sys cleaner crap...
Got the same problem with cylinder #1. The deposit is ash from burning oil. I haven't figured where the oil is getting in but most likely the ring however could be the valve seals as well.
https://honda-tech.com/zerothread?id=918825
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Got the same problem with cylinder #1. The deposit is ash from burning oil. I haven't figured where the oil is getting in but most likely the ring however could be the valve seals as well.
https://honda-tech.com/zerothread?id=918825</TD></TR></TABLE>
thanks for the help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lsskunk »</TD></TR><TR><TD CLASS="quote">check exhaust blue smoke ='s oil being burnt
The weird part is that I can take it up to 6k and no smoke comes out. The plugs have been in there for about 10k miles and the others are clean. I think my valves are letting just enough oil get by for it to accumulate over time. I haven't had an adjustment in 15k so I am due. no biggie for now as the car still runs fine. thanks
93SSPHatch
May 30, 2002 04:27 PM
