Stock or Aftermarket for Minimal Exhaust Noise?
Old Feb 28, 2005 | 06:10 PM
TheSSG's Avatar
Default Stock or Aftermarket for Minimal Exhaust Noise?
I have a '90 HF, and my muffler just fell off.
I would like to get the quietest exhaust Possible (I My Car is not performance oriented, it is geared for Audio [It is COMPLETELY deadened; Liquid Deadener, 80mil Deadening Mats, Neoprene Foam, and 1/8" Mass Loaded Vinyl]).
I found the RSR Exmag, and I was wondering:
Is this Performance, and quiet
or
Quiet, which can be performance?
Basically, is this the quietest performance exhaust, or the quietest exhaut?
I'm not sure if the High pricetag is justified, as there will be no other performance upgrades, but if it will actually last a long time (Read: Not Rust), I think it would be a decent idea.
Old Feb 28, 2005 | 06:43 PM
b16_madman's Avatar
Default Re: Stock or Aftermarket for Minimal Exhaust Noise? (TheSSG)
It isn't that loud of one, but then again, I enjoy it's note. Try hks if you want to be a baller and be quiet. 2" piping keeps stuff quiet, but they're a) $$, and b) not SS
Old Mar 1, 2005 | 01:08 AM
crxnj's Avatar
Default Re: Stock or Aftermarket for Minimal Exhaust Noise? (B16_madman)
Get the oem exhaust and spray that bitch with high temp flat black paint..Its the queitest exhaust you can get..And its cheap
Old Mar 1, 2005 | 04:32 AM
davens's Avatar
Yeah, it's hard to beat the stock exhaust for quiet...problem is finding one. Most used ones are in some form of decay/rust. New OEM is ridiculous expensive. Just the muffler and pipes are $300+.
A HF doesn't need more then a 2" exhaust....that's bigger then the throttle body
I'd look find a new, complete 2.0" stainless system and add a few sound killers. Or have one built to your spec at a local muffler shop.
1. A resonator between the cat and the muffler
2. A resonated tip
3. An insert like *LINK*
4. A high quality muffler with three chambers...only two gets buzzy
That's about as quiet as you can get it.
Modified by davens at 8:08 AM 3/1/2005
Old Mar 1, 2005 | 04:46 AM
crxnj's Avatar
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
You have wiperblades in your exhaust?
Old Mar 1, 2005 | 05:12 AM
davens's Avatar
Default Re: (Mr.speaker)
Heh...stupid Summit site. look at the url...it says exhaust and insert. Go figure.
Try it now. If it still won't link properly, Go to Summit's site and look up Car Chemistry Exhaust Inserts.
I had a buzzy Mazdaspeed Protege exhaust it quieted down enough to be tolerable. And they claim it doesn't hurt flow like the tail pipe inserts for the cheap bullet style mufflers have a tendency to do.
ZenDog73
17
May 25, 2012 05:54 PM
Ding
24
Oct 24, 2005 11:28 AM
eymnewdc4
Feb 13, 2005 04:02 AM
redteg1
Jan 24, 2002 04:48 PM
