oil leak
Old Feb 28, 2005 | 04:58 PM
sickerhatch's Avatar
Default oil leak
ok guys i just got my motor going about 200 miles ago.and ever since it has had a slow oil leak oround the head .it leaks right where the little part number tag is on the head gasket. the head and block were both machined and should be flat.the vtec silonoid gasket is new,cam plug is new,i even changed the hg and its the same thing.oh yea its a b16a,and i just did a full rebuild all oem parts.any one think the machine shop screwed up and the head or block isnt square.or any ideas would really help this is pissing me off. thanks
Old Feb 28, 2005 | 05:12 PM
NJIN BUILDR's Avatar
Default Re: oil leak (sickerhatch)
Sometimes when the block and head are machined the dowel pins can end up being to long.This can hold the head up off the block.
Glenn
Old Feb 28, 2005 | 05:35 PM
Default Re: oil leak (NJIN BUILDR)
the head and block were both machined .4 thousands is that enough to make the dowls to long?
Old Feb 28, 2005 | 05:38 PM
dunkd's Avatar
try retorqueing your headstuds.
Old Feb 28, 2005 | 06:43 PM
Default Re: (dunkd)
any more ideas
Old Feb 28, 2005 | 06:53 PM
sporkcrx's Avatar
Default Re: (sickerhatch)
I have the same problem, and now it leaks a lil coolant when some boost is thrown in. I bet it's those god damn dowel pins Now I'll have to do a headgasket job again just to flatten them down.
Old Feb 28, 2005 | 06:57 PM
Default Re: (sporkcrx)
how much did you mill your head and or block?
Old Feb 28, 2005 | 07:30 PM
sporkcrx's Avatar
The head got flattened when I did the last head gasket job. They stamped how much they took off on the head, but I can't see it now so I'm not sure.
Old Feb 28, 2005 | 07:42 PM
99B16Si's Avatar
i bet its your dist. o-ring
Old Mar 1, 2005 | 03:19 PM
Default Re: (99B16Si)
ok i went to honda and got a dizzy o ring going to put it on right now,ill let you guys know.
Sr420Det
Apr 16, 2011 02:55 PM
newbiehonda_05
Sep 22, 2006 04:37 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
ITR_1211
Jan 5, 2004 09:04 PM
C4wrx
Aug 4, 2002 06:23 PM
