Brake differences on a 4g lude.. Vtec-SI?
Old Feb 28, 2005 | 04:55 PM
tarheelsoldier's Avatar
Default Brake differences on a 4g lude.. Vtec-SI?
My question is pretty plain. what are the differences between the Vtec brakes and the Si brakes. i am guessing rotor size, but i am curious by how much etc. if yall have any information please tell me.
Old Feb 28, 2005 | 05:16 PM
luder94-ChrisA's Avatar
Default Re: Brake differences on a 4g lude.. Vtec-SI? (tarheelsoldier)
1) IIRC, Si front Rotors are ~10.3" diameter & VTEC front rotors are ~11.1"diameter.
2) VTEC front calipers are larger than Si front calipers as VTEC pads are larger than Si pads.
3) Master cylinder is the same for both Si & VTEC models (but is smaller on 4th gen S models). Also, the rear discs, calipers, & pads are the same size on S, Si, & VTEC models.
Old Feb 28, 2005 | 05:42 PM
leonard1818's Avatar
Actually, I'm looking forward to doing this swap in the near future. If you check my watched topics you can find the one that i started. Theres some helpful links in that. The only reason I'm doing it is because i need new front rotors/pads and these brakes only lasted a year (but we wont get into that) so I figure why not? If you need new brakes do it!
Old Mar 1, 2005 | 05:51 PM
Default Re: Brake differences on a 4g lude.. Vtec-SI? (leonard1818)
i am looking to do a brake swap but i am not sure if i am goin with the Vtec caliper or the twin piston calipers. and i was just curious about the rotor cause it always puzzled me and so i figured i asked while i am trying to figure out what i am gonna do with no abs
Old Mar 2, 2005 | 12:43 AM
vtecludeh22's Avatar
the vtec brakes really arn't that much different performance wise. if you really want to do something good i would do NSX callipers and get legand rotors and drill them to 4x114.5. i was looking to do it to my si-vtec lude before i decited to sell it.
Old Mar 2, 2005 | 03:38 AM
The Phil's Avatar
Default Re: Brake differences on a 4g lude.. Vtec-SI? (vtecludeh22)
Legend and prelude vtec rotors are the same diameter, no need to redrill the rotors.
X01Michael
Dec 10, 2010 08:38 PM
spnbb2
Oct 13, 2004 06:11 PM
hOndafienD 04
Sep 11, 2004 07:18 PM
mattmw88
Apr 15, 2004 08:22 AM
illusion
Oct 29, 2003 02:55 AM
