knock from engine
Old Feb 28, 2005 | 04:11 PM
SPORT INJECTION's Avatar
Default knock from engine
nice knock coming from under 2nd plug wire.... cant even push plug wire on all the way. any ideas... im hoping I just need a valve adjustment? maybe could just be a plug?
Old Feb 28, 2005 | 04:21 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: knock from engine (SPORT INJECTION)
I don't see how a knocking noise inside the motor would prevent you from clipping your plug wire on the plug. Have you removed / inspected the plug? Is it damaged in any way? A bad valve adjustment sounds more like a louder tapping rather than a knock.
Old Feb 28, 2005 | 04:44 PM
Default Re: knock from engine (LSVTEC 91 Civic)
the other wires snap on and off with ease... where the noise is coming from it wont snap all the way on.
Old Mar 1, 2005 | 07:56 AM
simple fix..... wow im happy. loose plug. there was even some oil on the plug wire. can someone explain to me why it was knocking when it was loose? just curious on the technical stuff... what exactly was the noise? thanks
Old Mar 1, 2005 | 08:08 AM
slowpokesi's Avatar
it wasnt knocking it was probably vibrating since the plug wire wasnt connected properly.
Old Mar 1, 2005 | 01:07 PM
scramblerman's Avatar
If the plug was that loose it was the sound of air....compression
Old Mar 2, 2005 | 02:02 PM
Default Re: knock from engine (scramblerman)
hmmmmmm
1SlowSi
May 30, 2008 04:25 AM
quicksilverej6
Mar 22, 2006 05:48 PM
user 72830283
13
Sep 18, 2005 12:20 PM
WickidSi
Feb 1, 2003 06:26 PM
