What parts do I need to install the skunk manifold?
I heard that I will need a Type R intake as well as a type R t/b cable, cable hanger, and pulley.
I wish Cspeed had instructions on this on their site.
[Modified by Mugenblkgsr2000, 9:53 AM 1/21/2002]
all i used was a IM gasket, and typeR CAI.....if you have the money get a ITR TB, cable, and bracket....else you can't keep your stock strut bar, and you will have to lower the GSR TB bracket.....but i got a new strut bar and haven't had any problems with the GSR hardware
You don't need any new parts except maybe a new intake. My aem short ram for the gsr still fits but doesn't fasten down as well. As far a gaskets, my manifold gasket stayed stuck to the head so i didn't have to buy a new one and i peeled off the TB gasket carefully so i could reuse it. When u put the new manifold on and attach the throttle cable bracket there will be 2 bolts that you are supposed to use. What i did was just move the bracket down so that the top hole on the bracket was bolted into the bottom hole on the manifold (its only held on by 1 bolt instead of 2, but it holds fine). this allowed more clearance for the hood. As for the strut bar, just turn it around and it fits. hope that helped, good luck
[Modified by duke5561, 8:43 PM 1/21/2002]
all you need is some vacumm hose and maybe a brass t fitting nothing else. Also lots of patience getting the bottom bolts off are annoying
vlc92189
Feb 5, 2007 06:49 PM
d_mina
Jul 20, 2004 08:07 AM
The Poopsmith
Jun 16, 2003 07:24 AM
Roger
May 26, 2002 08:22 PM
