what do I need for my single v-tec swap???????info
Old Feb 28, 2005 | 03:28 PM
TheJunBuilt's Avatar
Default what do I need for my single v-tec swap???????info
Ok I just bought the cleanest of ef si.....I am going to order a swap the d15b which ahs like 130hp and a messly 106tq if that??? the question I have is what all Do i need to buy ....I know I need to buy a si tranny so it will bolt up....but Like I dont have shift linkige or any thing so what all do I need.... and will headers ..intake and exaust help.?
Old Feb 28, 2005 | 03:42 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: what do I need for my single v-tec swap???????info (SirJdm)
needa search
Old Feb 28, 2005 | 03:44 PM
Default Re: what do I need for my single v-tec swap???????info (Ace$nyper)
yeah I dont know what exactly i need like ..The swap comes with everything exept like shift linkage ....what shift linkage will work witgh the single vtec... si tranny
Old Feb 28, 2005 | 04:01 PM
bumpdizle?
Old Feb 28, 2005 | 04:06 PM
Dwight Schrute's Avatar
you need a way to activate vtec. the best way is by converting to obd 1 and using the correct ecu which is hard to find for the d15b vtec. you can use the z6 ecu, p28. you can covert to obd1 with a obd0->1 conversion harness. they are sold on the forums just search.
as far as the shift linkage, you just need on for an ef hatch.
Old Feb 28, 2005 | 05:37 PM
Rywire's Avatar
Default Re: what do I need for my single v-tec swap???????info (drewthomas14)
Ya, for sure go obd1 if you want to do it right.
Also hit up http://www.rywire.com for all your wiring.
Ryan
Old Feb 28, 2005 | 05:44 PM
crxnj's Avatar
Default Re: what do I need for my single v-tec swap???????info (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirJdm &raquo;</TD></TR><TR><TD CLASS="quote"> yeah I dont know what exactly i need like ..The swap comes with everything exept like shift linkage ....what shift linkage will work witgh the single vtec... si tranny
Use the 88-91 civic/crx linkage..
Convert your car to obd1 and add the wires for vtec..
Run a p28 ecu..(Cheap and easy to find)
You get the intake and exhaust made for your car..And make them fit..
EF HATCH90
Aug 27, 2009 04:52 AM
agiorlando
Nov 19, 2007 03:54 AM
civickid5835
Apr 14, 2006 12:06 AM
92civichatch1
Sep 7, 2005 09:57 AM
EF GUY
Sep 6, 2005 12:10 AM
