Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY???
i saw an ek on HT with gsr cluster. is this plug and play? if not... what needs to be changed or modified???
You need to repin the plugs. https://honda-tech.com/zerothread?id=1053318
Result...
I've done this swap 2.5 times. The .5 came when I swapped a 96 GSR cluster from an EK and put in a 98 spec JDM ITR cluster. I had to move two wires.
Result...
bballzplaya
Jul 25, 2008 09:24 PM
needforvtec
Oct 9, 2006 07:57 PM
